Question about HP DC170B Keyboard
Cleaned my HP keyboard now I can't type - HP DC170B Keyboard
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
I cleaned my keyboard, but keys `-1-q-a-z won't work.
You may have one of two options 1- these Keys are loose and should be pushed down you will hear in old keyboards a type of CLICK 2- in recent keyboards you should press these keys several times.
if it has been cleaned with a non volatile liquid you should be sure that the keyboard has been completely dry specially at these keys
Nov 17, 2009 | LG Keys-U-See Keyboard
2 keys on keyboard dont work
send it to the manufacture caustamer care and replace it.
Jan 13, 2009 | HP CPQ175KB Keyboard
Keyboard trouble
ok in the keyboard there is fn right. Hold FN+Number lock (num lk) then it should transfer back to letters
Jan 02, 2009 | Computers & Internet
Compaq laptop keyboard mulfunction
try having your laptop checked by a competent technician... there might be an obstruction in your keyboard (like dust) which causes the key to stuck and have it cleaned
Aug 09, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Keyboard not responding or typing random letters
You have stuck keys from when you removed to clean. Remove the stuck keys and see if it works OK when you press the rubber cap instead of key
The back space one may have a link under it if it is a wide one ensure it is fitted correctly
Aug 09, 2008 | HP P2360AA Keyboard/Mouse
HP Compaq NX960 Laptop Keyboard Problem
This is generally a sensitivity issue with the keyboard. It's usually caused when the rubber depressors that activate each key start getting worn. Sometimes you can take each key off individually, take off the rubber depressor and clean the contact point on the keyboard and up inside the depressor where it makes contact. Clean it with with rubbing alcohol and Q-tips. This is alot of work and only fixes the problem about 60% of the time. Your only other option is replacing the keyboard.
Jul 23, 2008 | HP Pavilion dv1000 Notebook
HP slimline home computer's keyboard
Either the keyboard is bad or the port that the keyboard plugs into is bad. Try either another keyboard or your keyboard on another computer to narrow it down. If it is your computer and the keyboard is a ps/2 keyboard, then you can just replace it with a USB one.
Jun 15, 2008 | HP Pavilion Slimline S7410N Notebook
HP DC170B Keyboard Logo
37 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
