Question about Intermatic & Indoor/Outdoor Rain Tight Timer
IS IT POSSIBLE TO WIRE A INTERMATICTIMMER T104 WITH 120VOLTS
  • Intermatic Master
  • 5,245 Answers
Replacing 4 wire 3 speed fan switch with 3 wire 3 speed fan switch. Is it possible??
No it is not going to. If it does then why did they use the four wires in the first place? Duh!
If you cap the ground wire nada will work - if you cap one of the wires going to a motor winding, that speed will not work.
Feb 21, 2016 | Westinghouse Electric Dryers
Is it possible to repair a broken wire
you can repair a broken wire provided you know exactly the pt where the wire is broken..... just turn the wire left and right at suspecious points and listen to the sound..... if you can hear a change in sound at any point, conclude that it is broken there.... cut the wire at that point and solder the wires back in the correct combination to make it work fine...
Sep 24, 2014 | Rider Cardo Scala Q2 Multiset Headset...
Bike bogs down when given gas
possible grounding of coil wire. also confirm your battery is not older than 4 years.
Aug 05, 2012 | Yamaha V Star Classic 650 Motorcycles
How do u connect the amp
Run a power wire from the positive battery terminal to the red power wire on your amp. Without extending the length of the ground wire if possible connect it to a clean ground connection as close to the amplifier as possible. Wire your speakers to the proper terminals, make sure you do not exceed the capabilities of the amplifier i.e. impedance matching. Connect the blue wire to the power ant or remote connection on the back of the radio usually a thin blue with white stripe or plain blue. screw amp to the car..enjoy
Apr 08, 2011 | Rockford Fosgate Punch P5002 Car Audio...
How do i wire a 500k micro farad compacitor ot my exsiting amp? need a wire diagram or detailed instructions thanks
The capacitor has two terminals. One is + and one is - . Your Amplifier has three terminals on the power connector. One is connected by a Black wire connected to the body or - of the battery, the second is a Blue wire connected to the remote wire of the Head unit ( for remote ON/OFF of the Power Amp ). The third is the Red wire connected to the + terminal of battery through a big Fuse .
Connect the Capacitor + to the terminal with the Red wire and Connect the Capacitor - to the terminal with the Black wire. Make sure you use heavy cables to do the connection and try to keep the length of the interconnecting cables as short as possible ( to minimize losses ). In other words try to connect the Capacitor as close as possible to the Power Amplifier for maximum efficiencybobhifi_26.jpg.moz-screenshot.pngmoz-screenshot-1.png
Mar 31, 2011 | Car Audio & Video
I have a JS968 GE Profile range that the ASM sensor went bad. When pulling the sensor to replace it with the new I discovered that the plastic connectors had disintegrated from heat. Is it possible to...
Hi. Yes it is possible to connect the wires with wire nuts. (Without tape! / tape can melt) You must use ceramic / porcelain wire nuts (white) in HOT areas. Make sure it is a clean connection with no copper strands exposed The plastic ones will melt like your connector did. Most appliance parts supply stores will have ceramic / porcelain wire nuts.
Here is a source for ceramic wire nuts if you can not find them. (15 ea / pack) $5.65 +shipping
http://www.repairclinic.com/PartDetail/Porcelain-Wire-Nuts/241068
Thanks for choosing FixYa,
Kelly
Nov 08, 2010 | GE Kitchen Ranges
I have a 95 f150 wheni put the truck in reverse it stalls an blows a big 30 amp fuse under the hood
Just a guess...but I suspect that your brake light power wire is shorted somewhere. Follow it as far as possible and look for frayed insulation. If you cannot find bad wire, then pull both brake lights and check the power wire with an ohmmeter. If you see a short to ground, then it confirms a bad wire. You will have to recheck or bypass the wire run (by cutting the wire as close to the brake switch as possible and running a new wire to the brake light connection.
Let us know what you find!!
Oct 09, 2009 | 1997 Ford F150 Regular Cab
When you turn the burner on, the lighting around the knob does not light up. How do I fix this? Jenn-air cooktop cce3531
There are only two possible solution to this problem one of which is that your indicator light is faulty and will need to be replaced. part number for the indicator light is 706125. the other possible solution will be that the wire has simply burned and the part number for this wire is 706091. I`m not sure why there is a ``special`` wire part number. A generic high temperature wire will be sufficient.hope this helps.
Thanks
Oct 08, 2009 | Cooktops
3 wire white rogers zone valve operated by 2 wire thermostat any one have a wiring diagram?
It is technically possible use a 2-wire thermostat with a 3-wire zone valve, but you need a single pole, double throw relay like a fan control relay with one normally open switch and one normally closed switch. 2-wire thermostats only have one switch that is normally open. 3-wire thermostats have two switches......one switch that is normally open, and one switch that is normally closed. The fan relay lets the 2-wire thermostat simulate a 3-wire thermostat. It's possible, but usually it's easier to just get a 3-wire thermosts.
Sep 06, 2009 | Heating & Cooling
Is it possible to wire a Alpine CHM-S620 6cd to a home music ?
yes it is possible, but you need to goto a radio shack or electronic store and pick up a 12 volt power supply, then you will have the 12 volts needed so you dont blow it all up putting household current thru it...
Jun 12, 2009 | Alpine CDM-9821 CD Player
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
49 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
