Question about Simplicity Vacuums
Why does s24 cuts power nozzle cuts out put pulling backwards?
My kirby heritage II vacuum hose has a cut near the end of the metal nozzle. Is there a way to replace just the hose or even just cut off the damaged section and reattach to the metal nozzle?
We do carry a brand new Heritage II hose here. I do not know how you would cut and reattach the hose without losing hose integrity. You can try submerging the end in warm almost hot water and pulling off the end, cut the hose, and squeeze the end back in. But your hose will be shorter and I am not sure if it will work depending on how it is torn.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Sep 13, 2014 | Kirby Heritage II Vacuum
When I vacuum with the power nozzle, it keeps cutting off. Do I need to replace the hose or the power nozzle?
Not necessarily. It's hard to tell without checking it out. I strongly recommend taking it to an authorized Aerus Electrolux store and letting the service tech check it.
If you have the "Sidekick", you can try using it. If it still cuts out, it's the hose. If not, the wiring in the power nozzle is loose or worn and needs to be replaced.
Keep in mind that you may not need to replace the hose or power nozzle, just have some wiring repaired.
Nov 07, 2010 | Electrolux Epic 6500 Vacuum
Whenever we use our central vac the power cuts in and out often. It happens at all outlets. When I borrowed the neighbour's hose it did the same thing. So I assume I can rule out a short in the hose. Any...
Not necessarily. If the neighbors have the same problem, it could still be the hose. Try your hose at their place.
You can also use their hose AND power nozzle at your place. If their power nozzle works fine, then it's loose or worn wiring in your power nozzle or connection. Also, you can try your power nozzle at their place to double check.
Check your power nozzle connection for discoloring, breaks, cracks, etc. Take to a shop to check internal wiring.
Oct 31, 2010 | Filter Queen Vacuums
How do I change the belt on my Sears vacuum?
Here's what you'll need to replace a belt on a Kenmore2_bing.gif canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking. On most Kenmore models it's either a grey switch cover to the right of the neck for your power nozzle, or it could also be a little red colored pole. The reset switch will turn all power off to the power nozzle. If you turn on the vacuum, and try turning on the power nozzle and you hear absolutely no noise, then it's possible it may just need to be reset. It also could mean that your hose may have a short circuit in it (pretty common on Kenmore), and the hose is not getting power down to the power nozzle. If however you turn on the power nozzle, and you can hear the motor in the power nozzle come on when you switch it to carpets, then mostly likely your belt needs to be changed. On the model that I was fixing, the reset switch is a grey color, and I highlighted the reset switch in red:
So we'll just say for this repair that you are able to hear some noise come on in the power nozzle, but the brush is still not turning. This indicates a bad belt. Here's how you can fix it:
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. Look on the both the left and the right sides of the power nozzle. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Step 5. Once the top housing has been removed you should now either see a white semi-circle shaped housing over top of the brush, or your model may not have this part (some did and others didn't). If yours has a long white part over top of the power nozzle, look at the back corners of this white colored housing, and you'll see two clips, one on each side. You need to push these clips in, and pull backwards at the same time.
Step 6. Once this white colored housing has been removed, or if you model didn't have this housing, you'll now have full access to the roller brush and belt. You should instantly be able to see the belt if it's broken, as it won't be connected to the roller brush. Simply pull straight up on the roller brush to remove it from the vacuum cleaner:
Step 7. Wrap one end of the belt around the metal motor shaft in the back of the nozzle. Wrap the other end through the roller brush, and stretch the brush back into the housing where it belongs. Simply reassemble the parts, and test the vacuum to make sure the brush spins!
If you don't hear the power nozzle motor come on when you change the hose from Floors to Carpeting, this either means the reset switch needs to be pushed, or that you have a bad hose that needs to be replaced.
If you would like help on how to diagnosis the electric hose to see if it's bad, please just use the Clarification Request here on Fixya. If you have any other questions, please feel free to ask me, I'm always more then happy to answer follow up questions. If this repair was helpful to you, please be sure to rate it as helpful by clicking the thumbs up icons at the top of the repair.
Thank you very much,
Chris J.
GoVacuum.com
Apr 15, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Need to replace belt in Kenmore Vacuum Power-mate nozzle
Here's what you'll need to replace a belt on a Kenmore canister vacuum:
There are two different types of belts that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Chris J.
GoVacuum
Apr 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
The power head has developed an intermittent, but frequent, electrical short. Is there an easy way to assess where? Or is this a matter for a repair shop.
Greetings,
A majority of the time when this happens, it's caused by the hose having a short in it. You'll need to first identify what the source of the short it. To do this, turn the power brush on, and then swivel the hose on both the end before the handle, as well as the end that plugs into the vacuum, can you get the power brush to cut on/off for you from here? If yes, then you'll need to purchase a new hose. You may purchase this hose directly from Sears, however when you buy the hoses through Sears you have to assemble the hose yourself, which is very challenging. An easier way for you to replace the hose, is to purchase a Panasonic canister hose. There are two types of hoses, a 2 wire hose, and a 3 wire hose that fit most Kenmores. When you take the hose out of the canister, look on the part that plugs into the canister, how many prongs do you see here? If 2 then you'll need a 2 wire hose, if 3 then a 3 wire hose.
If you are not able to locate the short in the hose, then you may have a short either in the wand, or the power nozzle neck wire. For the wand, put one foot on your power nozzle while it's running, then pull up and down on the end of the wand that plugs into the canister, as well as the end that the hose plugs into. If you can get the vacuum power brush to cut on / off when you're doing this, this indicates your wand is bad and needs to be replaced. If it doesn't cut on / off, remove the wand and hose from the vacuum completely. Now look where the wand connects into the power nozzle. You should see two electrical prongs on the neck of the power nozzle. Do you see any burns, or black marks on the prong, or the plastic part that it comes out of? You can also test this part by turning the vacuum's neck to the left and to the right as if you were turning the vacuum.
Hopefully this helped you. If you need further help on figuring out which part is bad, please just use the clarification request here on Fixya, and I'll be happy to try and diagnose this further with you.
Thanks,
Chris J.
GoVacuum
Mar 25, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Miele power nozzle quits after 10 seconds of working.
Even though the brush is spinning, you probably need to replace the belt2_bing.gifbecause it is stretched. It is probably slipping on the beater bar.
Jim
Nov 30, 2009 | Miele Vacuums
Power nozzle works intermittently
The pin connection from the lower handle tube to the power nozzle are not making good contact. It is new, so i would have warranty service performed.
Nov 19, 2009 | Vacuums
Flair Cleaner makes squeaking noises
There are two items that could squeak:
If it squeaks when pushing/pulling it on carpet, WHILE NOT RUNNING, then the wheels are squeaking when they rotate on the wheel shaft. If so, one drop of oil at the shaft would fix it.
If it squeaks WHILE RUNNING, mostly while pulling backwards on carpet, then the belt is slipping. You may wish to set the nozzle height setting for a higher pile carpet, or could replace the rubber belt.
Oct 25, 2009 | Hoover Vacuums
Is there a drive belt on the heritage 84
Yes it has a belt. Could be the belt or a worn out brush roller, or you don't have the height adjustment set right. But I would check the belt first. It is the cheapest part and if you haven't changed it lately it probably needs it anyhow.
If you haven't changed the belt before it's a little tricky.
Turn the knob on the front to the belt off position, and unlatch the top of the nozzle to remove it. Pull the nozzle off and turn the knob to the belt on position. Take off the bottom plate and take out the old brush roller and belt. Pay special attention to how the roller comes out. You don't want to get it in backward.
Put the new belt on the roller and center it. Put the roller back into the nozzle and put the bottom plate back on. Turn the knob to the belt off position you should be able to see through the hole in the back, the hook pick up the belt and stretch in up.
Put the nozzle back on the unit, latch the top, and turn the knob to the belt on position. Simple Right? LOL
It has to be one of the most complicated machines to change a belt on .
P.S. they usually give you extra belt when you buy it, and the new style knurled belts work fine as well.
Good Luck-Don't be afraid to ask another question if that doesn't solve your problem.
Dec 01, 2008 | Kirby Heritage II Vacuum
Vacuums Logo
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
