Question about Electrolux Guardian Bagged Canister Vacuum
Is there a blow out on the exectrolux oxygen?
Kenmore 116.22612 will not suck...only blows out. Checked for all clogs, put in new bag, cut away all long hairs circling the rotator brush and let it cool off. Now what?
All things being equal, it would be helpful to know what has happened since the last time it was used? and how long ago that was? One thing to check, there must be a bag in the unit or it will not have much, if any, suction. However, other than that there's no good reason for this action.
Oct 21, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Oxygen Canister doesn't work.
something is blocked/clogged up check the filters.adrian,,,,
Jul 07, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Mine did the same thing
poor quality parts= problematic machines
Aug 29, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuum just stopped working.
is there a filter in it if so clean the filter.try it without the bag in it.make sure the bag is in correctly.does the bag expand when you turn it on.you might have something caught up in the hose.take the hose off and blow througfh it.if you can't its clogged.also check the inlet where the dirt goes into the bag.the inlet might be clogged.please leave feedback
May 04, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Need to find a part for my vacuum.
I can get you that part number, however when I try ordering it through any of my vendor it is next to impossible to locate. Will post number soon.
Dec 17, 2008 | Vacuums
I don't have a manual........ help!
http://www.aerusonline.com/service/manuals.cfm
There is a pull down menu to select the manual you need. Look for "Lux Floor Pro". Good Luck!!
Dec 08, 2008 | Electrolux Floor Pro Vacuum
Need source for Electrolux Oxygen parts!
Some parts can be found here: http://www.vacuums24x7.com/elox3ulcocav.html
Unfortunately they don't have the part I need.
Jul 15, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Guardian Bagged Canister Vacuum Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
