Question about Hunter 27185 Remote Control
2722 manual remote control - Hunter 27185 Remote Control
How can i get a replacement remote control unit for my TV
I have a remote for my norcent tv, My tv is at home, I am on the road, I have found a remote but I do not know if it will work on my tv. The number I found on the remote is 681T where the batteries go. Which tv does this remote work. Thanks in advance, Mark
May 28, 2011 | Norcent Technologies LT-2722 27 in. LCD...
My TV changes channels or source by itself. I
This may or may not be your solution.
The tact switches (push buttons) mounted on the circuit board may need to be replaced (old, worn, sticking). These are the buttons that are pressed in when you use the controls on the television set (volume, menu, channels etc.). Try removing all of these switches (don't remove the remote sensor). Don't remove just the channel switches.
If you have a remote than you don't 'have' to replace them, only if you want to control the tv from the set itself. After you remove them see if you have the same issue. If so you may need a new control IC chip.
A repair shop will charge about $75 to replace the buttons. If you have the tools and knowledge than feel free to do it yourself. To remove mine, I just used pliers and was careful. However to replace them you will need a soldering iron.
Mar 02, 2010 | Norcent Technologies LT-2722 27 in. LCD...
Need Universal remote for a Norcent LCD tv...
Try website 1-800-Remotes Factory original.To buy an exact remote.
Dec 23, 2009 | Norcent Technologies LT-2722 27 in. LCD...
Auto program channels manually
the only way is with the original remote for the set.
Aug 07, 2009 | Quasar SP-2722 27" TV
Unlock parental control
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Apr 01, 2009 | Quasar SP-2722 27" TV
Cant find the code to set my tv for the dish's remote control
usually the remote has a scanning option where you enter certain button commands. some are automatic but some require pushing a button until the device reacts, but i have a tendency to go to fast and pass it up. sure am glad when the instruction manual tells how to go backwards with the scan....lol...... the manual for the dish reciever should explain exactly how to do this as well as some common codes. i found that even if mine is not lsted, someimes the codes for a different type of device by the same or similar manufacturer woll be correct. if you do not have the manual i am sure dish has it on their website. oh...........pretty much any standard after market remote you cam purchase will work, and buy one that has the auto scan....lol............it is so much easier than pushing a button 100 or more times.
Sep 29, 2008 | Norcent Technologies LT-2722 27 in. LCD...
No power. Will not turn on with ir without the remote.
I HAVE A NORCENT LCD TV -MODEL NO LT 2723
YOU TURN IT ON BUT NOTHING HAPPENS EVEN WITH THE REMOTE .
CAN YOU HELP ME FIGURE THIS ONE OUT.
THANK YOU, SO MUCH.
Sep 07, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Program the remote
try the auto scan feature explained in the instruction manual for the remote
Jun 09, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Televison & Video Logo
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
