Question about Minolta QMS 2560 Printer
Qms 2560 fuser
Replace teflon
  • Minolta Master
  • 6,161 Answers
Replace the fuser as a whole very rare you can even get parts quite old machine. QMS is now part of Konica Minolta
Posted on Dec 29, 2014
HP LJ P3015 Printer not printing clearly after replace the sleeve
Reasons:
1. Teflon Sleeve, use better quality sleeve.
2. Apply good quality of Teflon grease.(Don't apply more or less)
3. Chk Fuser temperature..& connectors..
4. Adjust Fuser temperature in fuser mode..
May 23, 2014 | HP Laserjet P3015X Printer
There was a problem with teflon sleeve in hp 1020 printer. so i replaced new teflon sleeve. But after i replaced teflon sleeve i faced a new problem. that is, there is a noise just like a drum frictio
when replacing the Teflon sleeve did you clean the heating element? if so did you also re apply new fuser lube? this Lube is not a normal lube.. its a lube that is specifically manufactured for fuser units and Teflon sleeves.. you can buy it thru a Company called Precision Roller look them up on line
Apr 01, 2014 | HP LaserJet 1020 Printer
All our printed documents are coming out with a smudged line on both sides of the printed documents. Is there a way to self clean the printer?
Service engineers:Are you replaced Teflon Sleeve?, If yes replace with another sleeve with good grease/paste.
For users: Through Fuser cleaning mode U can clean, but it won't give effective result. Try this. Go 2 menu, scroll 2 device manager, scroll 2 system setup, scroll to print quality, scroll 2 fuser modes, scroll 2 fuser cleaning enter.. If U are not satisfied replace fuser assembly Or teflon sleeve..
Oct 02, 2013 | HP LaserJet P4015N Printer
The print smears on the page. I need to print several copies before the print will not smear.
Symptom that Teflon sleeve not rotating properly..If you are Tec guy replace Teflon sleeve & Pressure roller at a time to shoot out the issue..or else replace fuser assembly.. P/No:RM1-3740-000(120V),RM1-3741-000(220V)..if you are observed grinding sound, replace 20T gear P/No RU5-0378..Along with the fuser..See the snap shot..10_28_2011_5_41_54_pm.jpg
Oct 28, 2011 | HP LaserJet P3005n Printer
The IT Dept. at work gave me a Laserjet 2420. When I print something, it appears that ink is stuck to the roller and will reproduce faded lines further down in the page. I would describe it as the toner is...
Faulty cartride or fuser causes ghoost image in print outs. Primary level:check with another cartridge. Secondry level: Remove fuser assm out, check teflon sleeve surface deposited with toner?. replace teflon sleeve if available if not replace fuser assm. In fuser modes we can increase/decrese the temparature of fuser.
Note: only service engineer can replace the teflon sleeve.. user not advisable
Sep 21, 2011 | HP LaserJet 2420 Printer
Printed copies come out crumpled or with drag marks on the long edges. Looks like something like a piece of paper could be stuck in there but I can't find anything.
Sympton look like teflon slee damaged in fuser, remove fuser assm check damage, if teflon avail repace or else replace fuser assm...
Sep 09, 2011 | HP LaserJet P3005d Printer
Hi i have two hp2015 ans the printer has started to smear the ink on the rollers, would the fuser need replacing or is it the paper type?
The function of Fuser (covered by Teflon sheet) is to heat the paper in order to fuse the toner to the paper. Toner sometimes smears after the print 1. If the fuser is not heating properly, 2. Teflon (Fuser sleeve) is damaged or 3 Paper is thick (Card). If you are using normal paper, then it could be the fuser.
Hope it helps! Good Luck!
CreativeTECH
Feb 04, 2011 | Office Equipment & Supplies
Minolta QMS 2560 gets NIC overload after printing 6 or 7 pp.
check if it happens with any other machine to narrow down the problem.Once you know if its the printer or the MAC it would be easier to fix.MAC usually does not give problems.
Jul 06, 2009 | Minolta QMS 2560 Printer
I have changed the printer cartridge three times. The first two cartridges produces totally black copies; the third one has black horizontal thick lines across the page??? H E L P !
It is may be Problem with printer Fuser.
1.Confirm there is no paper pieces in backside fuser unit.if yes remove the printer cover take out the fuser unit and remove the paper pieces.
2.if there is no paper pieces you must replace
fuser unit Teflon or entire fuser unit. ordinary teflon costs about Rs300.(6 dollars)
Jun 30, 2009 | HP LaserJet 1150 Printer
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
