While i adjust my toshiba 8893 7D65 tv's factory mode adjustments in page F8, in a time i change 0 to 1 then tv screan goes off. I try several times but it not ready. What can i do?
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
  • 18 Answers
SOURCE: camera is locked up
I have found that most lock-up problems are the result of some obstruction (sand, grit) or perhaps impact damage. Send it to me for a N/C estimate. I've been in the camera repair business for over 30 years. www.flcamerarepair.com
Posted on May 09, 2008
  • 4 Answers
SOURCE: STILL GOES TO COPYWRIGHT PAGE
try del or tab to start safe mode
Posted on Apr 04, 2009
My toshiba tv will not let me change the digital audio selector
Try a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 23, 2016 | Toshiba Televison & Video
When I turn on my Toshiba TV it tells me the fan stopped working and it turns off. the last time this happened I had to reset the TV somehow. My question is how do i do a hard reset?
Mar 31, 2016 | Toshiba Televison & Video
I have a Toshiba TV 40L3400U. When I try to access Netflix, I get a screen that says "a software upgrade is available, it will take more than several minutes, Toshiba strongly recommends that you perform...
Try a reset to this TV and check. If it do not help you, contact the authorized service center. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 02, 2015 | Televison & Video
How do I get to hidden service menu to reset machine to factory?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 23, 2014 | Toshiba 22AV500U 22 in. LCD TV
Cant restore to factory settings tried 0,f1 and f8 none work
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
Aug 16, 2011 | Toshiba Satellite Pro L300 Notebook
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
TV powers on screan comes and then powers off after a few seconds
Pls look on your remote control, select the "sleep mode" to off. Sleep mode might be on. Or adjust the time whrere what time you want it off automatically. Just simplt turn ot off the Sleep mode. Check timer of your Tv.
Jan 18, 2011 | RCA HD61W66 61" Projection HDTV
Clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Perfect focus not working
I purchased mine about 5 months ago. Ive been researching and playing around with the remote. This will help you on the way. With the set off, press "Mute", 1, 8, 2 then turn the tv on. This will bring up the main settings, dont change any values on any page, unless you write the origonal values down first, because the total reset doesnt return everything to a "factory" preset. Scroll down to reset and press the enter key. I havent come across any owners or service manuals, and support is slim to none. I wrote a review for the same model on a wal-mart site I believe, and it explains adjustments in more detail. If you want to try to figure out the buttons for yourself, while the tv is on, press "Mute 1, 8, 3" this is another set of adjustments for finer detail. If you change an adjustment here and your not sure, just press the exit button. To save your adjustments in the convergence mode, press and hold the enter button, it should flash a few times and center itself on the screen. If you make a mistake in this mode, the total reset I mentioned first should get you back on track. If you find anything out or have a question, feel free to write me at Silverado1st@aol.com
Jan 15, 2008 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
