Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Aquarius wash and dryer
My aquuarius wash and drier is not pumping and filling with water and when i switch on its not making any noise.
  • 4 Answers
Can u please tell me what the problem is?
Posted on Jul 01, 2009
Hotpoint aquarius washing machine
Try unplug from electrical outlet wait 15 minutes and plug it in. If you are lucky it will reset. If you are not lucky it sounds like the circuit board may be damaged.
Apr 24, 2014 | Washing Machines
Our Hotpoint Aquarius dishwasher initially had the Eco & Prewash lights flashing & standing water inside. We then turned it on in the hope that the standing water would drain, which it did. It then...
Is it a dishwasher a washing machine or a drier? Washing machines don't have rotating arms and you said "I've managed to get the drier to drain"
I will assume it is a dishwasher in which case it sounds like your pump has failed.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WDD440 washer and dryer
Possibly Pump blocked. or impeller broken. without taking a proper look but sounds the obvious.
Jul 26, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint aquarius wd640 my boiler has broke so could you tell me if my washer drier is a hot or cold water fill
Most washers made today, are cold fill only, best way to check is look at rear of washer, and if there is only one hose, then it is cold fill only, if 2 hoses, then hot and cold fill..
So if your boiler is not working, then it should be o/k to use if cold fill only.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Programme 1
make sure both solenoids have a working supply (if two fitted) at rear.
Nov 15, 2006 | Candy DQW150 Front Load Washer / Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
74 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
