Question about SCOSCHE Specialty Adapters QUSBH ReVIVE IV - Power Adapter
QUSBH No charge device
How do i charge my tom tom
How do I charge my device? - TomTom
us.support.tomtom.com/.../how-do-i-charge-my-device%3F
TomTomApr 15, 2013 - If you only charge your TomTom while it is in use, it may not charge to capacity. To fully charge your TomTom, it is best to charge the device indoors. Most newer TomTom products can be charged directly through USB, simply by connecting the USB cable or dock to your computer.
Dec 18, 2015 | Cell Phones
To charge it or activate new device
Hello Maria
First you need to connect your GPS device to your computer with a USB Cord.(Which also charges your device)
Once that is done, you will need to download and install some soft-wares from the manufacturer website onto your computer which you will use to update your GPS device.Once all updates are installed,you are good to go.
To charge your device,connect your device to your car charger and plug into the charging compartment of your car
The link to download updates for your device is
http://www.tomtom.com/getstarted
May 22, 2015 | Tomtom GPS
Why does my Tp Link M5350 3G wifi turn on and off?
When ”high temperature” shows on the OLED screen, the device is too hot, so place it in a cool, ventilated location. When the temperature is high enough, the device will stop charging/functioning in order to avoid damage.
This device responds to overheating whether or not it is charging.
When the device is charging:
• The device is powered on. When the temperature is higher than 113°F/45°C but lower than 140°F/60°C, it will not show “high temperature” but it will stop charging.
• The device is powered on. When the temperature is higher than 140°F/60°C, it will power off & stop charging. Also the OLED screen will show ”high temperature” at that time.
• The device is powered off. When the temperature is higher than 113°F/45°C, it will stop charging & the OLED screen will show ”high temperature."
When the device isn’t charging:
• Only when the temperature is higher than 140°F/60°C, will the OLED screen show “high temperature” & this device will power off.
May 04, 2015 | Computers & Internet
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
HOW DO I CHARGE MY NUVI 1450 ?
use small size USB cable, connect with PC
Mar 28, 2011 | Garmin GPS
I CAN NOT CHARGER MY DEVICE IN USB
USB connection cables comprising of ports on computer telecommucnations devices are versatile outlets to managing multimedia. First the USB port on the device makes device to device connection where resoruces can be shared among several function requests. Second, the USB port on device least allows to derive power charge from another device only has to be attained from power outlet. For example, while a device is plugged into another device for media resources sharing is least like to attain power charging simultaneously. First use the USB port to power charge from an outlet to attain required functioning status. Circumspectively, the devices that have USB ports has several functions either as media resource sharing also for power circuit charging only each separarete process is attained where it is impossible to power charge a device while using the same port to derive functionality.
Feb 18, 2011 | Computers & Internet
Tmobile dash isn't turning on
  1. Verify that the OEM Charger and Battery are being used.
    • Only the AC charger, Car charger, or USB data cable that came with or was created for the device should be used; others can damage the device and/or battery.
  2. Is the device warm?
    • When using the device for prolonged periods of time, such as when you're talking on the phone, charging the battery or browsing the web, the device may become warm. In most cases, this condition is normal and therefore should not be interpreted as a problem with the device.The device has a protection feature that if the device becomes too warm (due to use of GPS while charging, BT while charging, using the device as a wireless modem, etc), the auto protection feature will be triggered and the charging process will be stopped. Once the device cools down, the device will then begin charging again.
  3. Check the USB Port on the device for any bent or misshapen PIN's.
    • If some are found, that is the most likely cause and this is considered physical damage not covered under the Warranty.
  4. Remove the battery and inspect the contacts.
    • Remove any debris/residue found on the device or battery contacts with a soft, dry cloth.
  5. Look closely at the battery contacts on the phone to see if they are bent out of shape.
    • If they are bent, the device will need to be exchanged.
  6. Try charging the device (try different power sources as well as chargers):
    • Plug in USB to device and PC; is the LED indicating that the device is charging?
      • Note: If the device isn't charging while connected via USB to a PC, go to Start>Settings>More>Power>Power Management and make sure that "When device is turned on, do not charge the device when connected to the PC" is set to OFF.
    • Plug in AC Charger to device and outlet; is the LED indicating that the device is charging?
      • LED indicators: Charging is indicated by a solid Amber light on the upper Left side of the face of the device.
        • Note: If the battery is completely dead, the light will be a solid RED for a few seconds while it is charging; once the device has enough power to turn on, the light will turn to Amber.
  7. Try another Power Source.
    • Try a different outlet to rule out that as the issue.
  8. Try another battery in the device.
    • If another battery doesn't work, perform a Hard Reset.
      • If the device powers up after Hard Reset, test the unit for a few days. If issue returns, device can be considered for an exchange.
      • If device shows charging with one (AC Charger or USB) and not the other, issue is with the accessory. Replace accessory.
      • If device will only power up when attached to charger (AC or USB) it is likely the battery needs to be replaced.
Device won't hold a Charge
The life of the battery between charging sessions will vary depending on which features of the unit are being used.
  1. Verify the you are using:
    • OEM AC Charger
    • OEM USB Data Cable
    • OEM Battery
  2. Fully charge the battery using the OEM AC Charger
    • USB and car chargers are trickle chargers meant to get the user through until they can get to their AC Charger.
  3. If the device is not lasting the advertised Talk time, with minimal use, try another OEM battery in the device.
  4. If the battery life still is not meeting the advertised Talk time (with minimal use), the device will need to be repair/replacement.
Device won't Power on
  1. Attempt to charge the device.
    • If the battery is dead, the device will need to charge for a few minutes and then should power on once this happens.
  2. Attempt to power the device on by pressing the Power Button for 3-5 seconds.
    • If the device doesn't power in, perform a Soft Reset using the stylus.
  3. If the device still doesn't power on, perform a Hard Reset.
  4. Try another battery.
  5. If the device still will not power on, it can then be considered for repair/replacement.
Handset Powers off
  1. Make sure that the device is actually powering off and not just going into hibernate mode by pressing the power button once.
    • If the screen comes back on, the device is not powering down.
  2. If possible, check the battery level by going to Start>Settings>More>Power>Power Management.
    • The charge should be no lower than 10%; if it is, charge the device and retest.
  3. Try another battery in the device.
    • If the device stays powered on with a different battery, the issue is with the accessory not the unit.
  4. If the device still powers off with another battery, Hard Reset the device and retest.
    • If the issue remains after the Hard Reset, the device it can then be considered for repair/replacement.
Nov 13, 2010 | T-Mobile Dash Smartphone
Charging batteryif i dont have a device to charge the actual batt
Yes, assuming the USB port into which you plug it provides enough current. Not all computer USB ports put out enough current to charge other devices.
Jul 11, 2010 | Vivitar ViviCam 8025 Digital Camera
Will not power up when charged
try restting your 920
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. If your device uses an SD card, insert the SD card.
Aug 26, 2009 | Tomtom GO 920 GPS Receiver
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
SCOSCHE Specialty Adapters QUSBH ReVIVE IV - Power Adapter Logo
41 people viewed this question
Top SCOSCHE Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a SCOSCHE Tool and Hardware - Other Expert? Answer questions, earn points and help others
