Question about Fuji FinePix S7000 Digital Camera
Cannot turn on the camera ,new batteries fitted
Batteries were flat so I replaced them with fresh ones ,the camera doesn't turn on
toto
  • 425 Answers
SOURCE: The batteries were drained in my FinePix S7000 camera whthe camera was not in use.
The CompactFlash card may have caused the batteries to drain. Some solid state CompactFlash cards consume power while inserted in the FinePix S7000 even if the camera is turned OFF. Fujifilm recommends removing the CompactFlash card when the camera is not in use. Microdrives and xD-Picture Cards do not exhibit this problem.
Posted on Aug 29, 2005
  • 3 Answers
SOURCE: fujifilm S3000 not turn on
Mine had with this problem....After checking everything I found some corrosion in the battery compartment so I cleaned the contacts at the bottom of the compartment and put a new set of batteries in...The camera started working again....DON'T leave batteries in if you are not using the camera >>>
Posted on Jul 03, 2007
SOURCE: battery life
Try buying very high quality recharable batteries. You might have low quality batteries and the camera eats the battery up quickly.
Posted on Mar 24, 2008
  • 22 Answers
SOURCE: NiMh Battery life camera shuts off powers down with full batteries
The battery cover shorting isssue is well known and can short a battery, but it would seem unlikely that it will deplete them that fast, as it takes about a day to do so with a fresh battery pack.
Instead, I would suggest you have a close look at your battery compartment contacts. NiMH batteries can leak when they get old, which can cause contact corrosion. Once you get corrosion the voltage can drop below the cutoff point and voilà, short battery life syndrome. Cleaning the contacts with an eraser or, if really bad, with some fine sandpaper should solve this problem.
If you don't use your camera a lot, remove the rechargeables at least once a month to recharge them and put them back in to keep the backup battery recharged. If they feel greasy they are leaking, discard them. NiMH batteries, whether used up a lot or not rarely last more than a few years.
HTH...
Posted on Sep 23, 2008
  • 244 Answers
SOURCE: My Finepix s5700 will not turn on even with new
A possible cause could be the "cut off" switch for the xd picture card door. Check the plastic tabs on the door for damage. If it looks ok then open and close it a few times to see if the micro switch on the board is stuck. This is a cut off switch to prevent accidental removal of the picture card whilst the camera is powered up. The battery door may have 1 aswell so best to check this also. If there is damage then you maybe able to effect a repair to the plastic tab or replace the door. if the micro switch is damaged then you can bypass with either a solder bridge or wire. Have you put the batteries in correctly? - just an after thought....
Posted on Jun 14, 2009
New batteries but the camera will not turn on.
New or old. They could still be faulty. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EASYSHARE M1063 Digital Camera
My kodak M763 lense is sutck and the camera wont turn on
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 12, 2010 | Kodak EASYSHARE M763 Digital Camera
When turning camera on the shutter opens then shuts straight away and switches off
Jan 11, 2010 | Kodak EasyShare M863 Digital Camera
The camera wont turn on
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 05, 2010 | Kodak MX1063 Digital Camera
It won't turn on it drop from me once and now it won't turn on
In order to clearly determine the fault the model of your KODAK camera is needed However I hope this will help: If your cam use AA batteries: Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. If your camera model requires the manufactures batteries: Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 03, 2010 | Kodak EasyShare One Digital Camera
I have a kodak v603 when i try and turn it on i have a red light that flashes under the camara icon on the top left next to the screen. the camara dosent seem to work at all. can any one please help thanks
Jan 01, 2010 | Kodak EasyShare V603 Digital Camera
Can't charge battery. The battery symbol is red. What do I do?
Dec 31, 2009 | Kodak EASYSHARE M340 Digital Camera
The batteries don't last. After 30 minutes, I
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. I heard that ONE cameras has a longer warranty that all other cameras. Your (KLIC-5000) 1050 mah Li-Ion rechargeable is covered under the same warranty as your camera. In order to organise your repair/Trade up/ accesony buy please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 19, 2009 | Kodak EasyShare One Digital Camera
My camara turns off when i turn it on even with new batteries
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 08, 2009 | Kodak Easyshare M753 Digital Camera
My camera won't charge
Dec 04, 2009 | Kodak EasyShare One Digital Camera
Fuji FinePix S7000 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
