Question about Toshiba 42H81 42" Rear Projection Television
42h81 RPTV I have a "wavy" pic that has lines and bars throughout the pic. It also jumps around constantly. I get the same thing with POP selected . It seems to be not as bad when first turned on then within minute ot two it is really bad, cannot even read menu or tell what the pic is. Any help is great.
  • 1,694 Answers
Rebuild hyper board = replace bad caps on board................T.
Posted on Nov 23, 2007
How do I fix wavy lines on Hauppauge Wintv hvr950q?
Are they wavy lines throughout the picture or are they just wavy on the side? Waving picture is usually caused by poor power supply filtering. Wavy lines throughout the picture are caused by interference. Try moving the device away from the computer with an extension USB cable it may be picking up interference from the surrounding electronic devices. It could also be defective.
Oct 19, 2014 | Hauppauge WinTV-HVR-950Q (1191) TV Input
Toshiba/ 42H81 / hyper board
You can either yrplace your Hyper board, or replace all the serfice mount capacitors in it. The cap replacement fixes this 90% of the time.
May 09, 2012 | Toshiba 42H81 42" Rear Projection...
Pulsating pic
there is a digtal board incased in metal right behind your input board change all the 10uf caps this should fix your problum
Apr 22, 2010 | Toshiba 42H81 42" Rear Projection...
My picture is wavy and out of focus. when i touch the auto focus it goes through the function but ends with failure. it is a toshiba 42h81.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Apr 14, 2010 | Toshiba 42H81 42" Rear Projection...
Mitsubishi WD5725 DLP set. Picture is Ok before
The set has over 150 capacitors that could be causing the problem but it is at least 1 doing this. Contact Mitsubishi. Some people have been able to get new replacment TVs because of this problem
Mar 04, 2010 | Mitsubishi Televison & Video
Green and pink wavy lines throughout. Picture
I am having the same problem and so far unable to fix,
Jan 22, 2010 | Pioneer SD-582HD5 58" Rear Projection...
Wavy lines
I would suggest you to use the Manual settings. Play with the ISO and the shutter. You will get a better pic.
- Ranjit
Nov 08, 2007 | Canon Digital Rebel / EOS-300D Digital...
Toshiba 42h81 rptv
Pull chassis--check all fuses,esp, F850 & F851.They protect
the B+ supplied to convergence circuit.They are found in the power
supply,on edge of the main board.On the signal board,locate the
large IC's mounted to heatsinks.IC part #  STK392-110.Between the
edge of the signal board and the IC's---locate two grey jumper wires
and some hard wire jumpers = solder them all,if you don't,the fuse may blow again.Next,replace IC's with Hitachi up-grade part
# STK394-160E....Reassemble...power on.....touch magic focus
and you are done....T.     ?????s-----Let me know...
Oct 28, 2007 | Toshiba 42H81 42" Rear Projection...
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 - Constant jumping picture on scren
it needs the hyper module replaced might as well have em do the stk packs too its too old to be a lemon the part that was replaced was not new it was in someone elses tv and had problems there too the trick is to find someone that will fix it so it lasts
Dec 05, 2006 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
61 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
