Question about Frigidaire ATF6000ES Front Load Washer
The washer continues to fill until it flood out
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand that your Frigidaire washer, model# ATF6000ES, continues to fill with water until it floods out. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. When power has been restored, select any cycle and start it. If your washer is still overfilling and flooding out, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to overfill and flood. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Posted on May 17, 2014
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: frigdaire heavy duty washer 13 cycles 2 speed motor. Washer no longer detects the water level. if you have it on small just continues to fill with water and never stops.. Washer flooded gargage. An
This can be due to failure of the pressure sensor within the washer which should output to the processor to cut off the inlet valve when the set water level has reached.
You can test this out by blowing into the tubing and testing the continuity of the switch to confirm if the diaphragm is intact.
click this link: Replacing sensor
Posted on Jul 05, 2012
Continues to fill with water, until the tub is way too full and floods out the back of the machine.
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Mar 29, 2011 | Washing Machines
Bowl continues to fill up with water causing
Pressure switch or pressure hose leaking ....or both
Oct 18, 2009 | Kenmore 22422 Top Load Washer
Tub will not start the wash cycle when filling, and will not stop filling
Hi, sounds like you wil need to change the inlet mixer valve. Did it continue to fill with the washer turned off? Let me know so I can assist you further.
Thanks
Vic
May 16, 2009 | Washing Machines
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
Kenmore fabric care washing machine FLOODING
so the water is backing out of your standpie in your wall? If it is flooding from the wall you need a plumber to snake it. that would not be a problem with the washer.
Jan 04, 2009 | Washing Machines
Water sometimes does not shut off. flooded twice. happens intermittently.
If when the machine is flooding if you turn off power to the machine and it continues to fill: replace water inlet valve. If flooding water stops filling when power is interupted: clean out the end of the water level switch tube where it connects to the outer wash tub.
Sep 17, 2008 | GE WHRE5260E Top Load Washer
Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Dec 12, 2006 | AEG Lavamat 88840 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
