Question about Dell 110v Fuser for B2360d/ B2360dn/ B3460dn/ B3465dn/ B3465dnf Laser Printers
PRINTER SAYING FLUSHING BUFFER - Dell 110v Fuser for B2360d/ B2360dn/ B3460dn/ B3465dn/ B3465dnf Laser Printers
Printer prints gibberish / screen says flushing buffer after I added this printer to an old dell desktop computer in classroom
Likely there were stale print jobs saved on the comptuer that were pointing to the port you connected the dell to. Or you may have a defective cable to corrupted driver.
Sep 12, 2015 | Dell 5210n Laser Printer
I've got a Lexmark T520 and it's not printing anything from photoshop - it says 'flushing buffer' and then just doesn't print. It will print from other sources i.e. web pages...
to large a data being sent for memory on printer photoshop will be hungry data and its has to small a memory to cope ok for normal printing but not this type of work
Aug 14, 2011 | Lexmark T644 Laser Printer
What is problem E 90
The ink tank is full and the printer is calling for a service engineer.Every time you switch on your printer, or change the ink, the printer cleans the heads by flushing ink through them. This leads to a load of waste ink in the bottom of your printer. In order not to get a messy desk Epson have put a counter on the flushing activity and the E90 error is saying this counter has reached the maximum.You have to reset this counter,to fix this error.
Mar 26, 2011 | Epson Stylus Photo R2400 InkJet Printer
Lexmark E 250 dn printer. Keeps turning off. Switching from blue bulb indicator to exclamation point indiator. Difficult to turn back on by pressing blue arrow button
The problem could be several things, the first one could be a Flushing buffer error. That means that the printer did not understand the print job sent to it and has to be reset in order to continue printing. Second could be a memory full error where the print job sent to the printer is too big and the printer memory is not enough. The third could be the printer front door is not closing properly, make sure the toner cartridge is installed correctly and that the front door is closed. That's all I can think of right now.
Jan 12, 2010 | Lexmark E250dn Laser Printer
Unable to clean
46 means the flushing tank is full. All you can do is take it to a shop to replace the flushing box and reset the count to get rid of the error...
Jun 29, 2009 | Office Equipment & Supplies
I have been printing chapters in a book. One chapter will not print. The message on the Lexmark screen is "flushing buffer". does anyone know what this means or why it will not print?
The 'flushing buffer' is most likely due to a corrupt file or file to large for the printer memory. You can check the file size and reduce it. Also you might want to upgrade your memory for the printer. Also might want to check your printer settings if the page you are having trouble printing is different from the other pages printed, such as text & graphics, etc. There is also a possibly of print program incompatibility or Windows OS Patch required but I doubt this since you have printed other pages without any problem. If you need to re-install Lexmark driver: http://downloads.lexmark.com/perl/downloads/downloads.cgi Or, if you need the Lexmark user's guide & reference guide: http://www.lexmark.com/publications/eng/optras/index.html
May 17, 2009 | Lexmark Optra S 1255 Laser Printer
What does "flushing buffer" mean
No response from the original poster as of 6/6/09. Normally, a "Flushing Buffer" message is pointing at a Postscript problem. A quick easy test would be to set the printer for PCL and retry the job. If it works, then you really need to look at the PS print file to find the error. Don
Jan 20, 2009 | Lexmark T644 Laser Printer
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
Printer not available
I installed the driver ADP 4.02E first and the printer was "Not Available" after that I uninstalled the driver and tried with a driver from epson-pos.com (ADP 4.02aE but the printer is always "Not Available"
I connected the printer after the installation, modify the DIPS to put the busy condition "Receive buffer full" as i see in the install guide
But it still not work...
Thanks for help
Jul 16, 2008 | Epson TM-U220 Matrix Printer
Lexmark c530dn wont print
disconnect this printer from your gigabit switch and try running it by itself. this printer should have its own on board memory. you may have uncompatible memories.
Apr 09, 2008 | Lexmark C530dn Laser Printer
Dell 110v Fuser for B2360d/ B2360dn/ B3460dn/ B3465dn/ B3465dnf Laser Printers Logo
164 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
