Question about Health & Beauty
Why do some people sweat alot - Health & Beauty
Tracfone customer service
I have found that most of the time the SIM card oxidizes (humidity, Sweat etc A soft clean rag with a bit of Methylated Spirit usually fixes the problem. Otherwise you may have to get a new SIM
Jul 21, 2014 | Android Cell Phones
Does the crown on the 609001 Technomarine have to be screwed in after the watch or date is set?
Yes, you must always screw down the crown. If not, you will get dirt, sweat, water inside and it will cost alot of money to repair
Jun 15, 2011 | TechnoMarine UF6 Lady Silicone Strap...
I got alot of sweat on my ipod and it wont turn on or do anything what can i do?
Thi is a typical problem for whihc many devices are not protected. Since the sweat contains a lot of salt, build up of the traces within the device can end up with shorting connections,looping circuits in the device rresulting in erratic behaviour. First off if you can carefully open the device do so with caution not to damage.delicate parts, then use a dry cloth to sponge off any watery fluids. if this is not seen/ visible use a hair dryer to warm up wihtout over heating for about 5-10 minutes. repeat this three times allowoing time in between, use a cleaner only if your careful not to damage the plastics specially petrol. Wipe dry before you reassemble. Hope this trick work out well. Good luck.
Jul 04, 2010 | Apple iPod touch
Leaking water behind engine appears to be coming from a chrome bottle looking like container
not sure on vw but on most cars that sounds like evaporator/dryer of the air conditioner system which under some conditions will sweat alot. the water you see leaking should be checked for color or oily feel
if it is just water and you have used the a/c there is nothing to worry about. if this helps please reply
good luck
Apr 26, 2010 | 2001 Volkswagen Passat
Can i vent into kitchen ?
You can vent into the kitchen, but, the amount of moisture that will be present in the air will cause dew/sweat to build up on walls,windows,ceiling everything in the room,and I mean alot of moisture!!!
If you are asking if this will harm the dryer, the answer is no the dryer will be just fine.
Good Luck !
Apr 21, 2010 | LG DLE2050 Dryer
Trying to replace the thermostat on a 2002 Grand Am GT V6 but having trouble getting to the bolts to loosen the coolant intake. Help?
These are in a tight spot. You may have to remove the exhaust crossover pipe to get it out. It can be done with some snap on swivel sockets and alot of sweat.
Dec 04, 2009 | 2002 Pontiac Grand Am
Engine light comes on goes off after turning off air cond
SOUNDS LIKE THE AIR CON NEEDS REGASSING OR THERE COULD BE A FAULT MABE WITH THE ELECTRIC FAN
Sep 01, 2009 | 1984 Mercury Grand Marquis
Strange water sound......
your evaporator drain tube is probably stopped up what you need to do is use compressed air to blow up the drain tube becareful because in humid climates the evaporator sweats alot and there can be alot of water in the evaporator case and it will come rushing out when the compressed air removes the blockage
Jan 31, 2009 | 2003 Lincoln Navigator
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
