Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
How to replace suspension rod on whirlpool thin twin
Suspension spring is broken
  • 15 Answers
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Posted on Mar 19, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
IFIXALL
  • 868 Answers
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
ned_san_jose
  • 230 Answers
SOURCE: Whirlpool heavy duty thin twin broken heater, the
Hi, thanks for the inquiry.
If it's a gas dryer, it's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
If it's an electric, it's either the heating element or the thermal cut-off, most of the time.
You'll proabably have to get to the element and fuse from the back. What I would do is just tilt the entire unit forward, if it's in a tight closet.
Best of luck and please feel free to contact me if you have any questions.
Ned
Posted on Sep 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Thin Twin Whirlpool stacked washer/dryer has a
You can do it yourself, them supports are pricey, your repair manual is HERE
Posted on Feb 12, 2010
Thin twin tub loose
you will need to remove the front panel of the washer,there are 3 spring suspension rods below the tub and either one or more of these springs are disconnected from the tub or broken
Dec 07, 2012 | Whirlpool LTE6234D Top Load Stacked...
I HAVE A WHIRLPOOL DUET SPORT DRYER I MOVED IT TO PUT ON NEW DUCT AND NOW THE DRUM IS HITING THE INSIDE OF CABINET HOW DO I FIX THIS?
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 21, 2010 | Whirlpool ET8CHEXSQ Dryer
Whirlpool Ultimate Care II off balance when spins
Mar 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Duet GHW1900 makes a lot of noise during the spin and rinse cycle
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%##
Dec 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer went out of balance during the spin cycle
Dec 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cabrio won't balance even empty
Check the four suspension rods on the outer tub to make sure they are not broken and/or out of placement.
Jun 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
The barrell has come loose on my thin twin stackable washer/dryer
The struts, shocks, springs...they are called different things depending on who you speak to. Apparently on the heavy duty thin twin stackable units they are all bad and last for about 13 months just after the manufacturers warranty, this is common knowledge among Whirlpool technicians and even the replacement parts that are being installed are not performing for the lifetime they were designed. I have contacted a repair service and they are scheduled for the middle of next week and over the phone he ballparked the estimate at about $300.00.
May 15, 2009 | Whirlpool LTE5243D Top Load Stacked...
WHIRLPOOL TOP LOAD WASHER-LSQ7030LQO- MACHINE WAS OFF BALANCE WE READJUSTED STARTED AGAIN- STILL OFF BALANCE- ADJUSTED STARTED AGAIN NOW IT MAKE HUMMING NOISE
Jan 28, 2009 | Washing Machines
I have a whirlpool top load washer.. mod number lsr5132pq4 and when it spins out it shakes and vibrates extremely loud
Dec 27, 2008 | Washing Machines
Whirlpool twin thin
You need to check the suspension of the washer, it could be pads, suspension springs, or even the shocks.
Jul 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
Dan Webster
Dan Webster
Sal DeAngelo
