Question about Poulan Pro " Pro" Self Propelled Mower
Does the poulan pro 650 lawn mower use plain gas or a mix?
  • 20 Answers
Plain
Posted on Aug 08, 2014
heres2maine
  • 84 Answers
SOURCE: how to change oil in poulan pro 650 series model
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
Posted on Apr 15, 2010
  • 189 Answers
SOURCE: what type of gas does the Poulan Pro lawn mower
just regular unleaded,same as you put in your car.
Posted on May 02, 2010
vincob
  • 718 Answers
SOURCE: what type of fuel do I use in my push Poulan Pro
If your mower is 2 cycle than there is a mixture, if it is 4cycle than there is no mix. Call your local repair shop and give them model number and they can assist you or call the place where you purchased the unit.. Good Luck....
Posted on Mar 12, 2011
Knucklebstr
  • 222 Answers
SOURCE: I just purchased a poulan lawn mower at Kents.
You do not mix gas in a 4 cycle engine. You have to mix gas and oil for a 2 cycle engine, such as in a weed whacker, chainsaw, or leaf blower. I do not know of any 2 cycle Poulan mowers (or any other brands for that matter). Unleaded gas is all you can buy in the United States and all current mowers will run on it, although they really don't like that new ethanol additive. If your mower is new then it should have come with an owner's manual which will explain what to do, as well. Hope this answers your question.
James
Posted on May 27, 2011
jlgprop
  • 352 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
FOR SURE CHECK ALL PREVIOUSLY MENTIONED ITEMS , TRY THIS...ALMOST GUARANTEE IT WILL RUN............ REMOVE "ALL" OLD FUEL, REFILL WITH FRESH HIGHEST OCTANE FUEL. REPLACE SPARK PLUG (YES, EVEN IF IT LOOKS OK!) GAIN ACCESS TO CARB OPENING, REMOVE AIR FILTER..OR WHATEVER. USING SPRAY CARB CLEANER, FILL ENTIRE CARB AND FLOATBOWL WITH CLEANER....WAIT OVERNIGHT IF POSSIBLE..IT WILL EVAPORATE. NEXT DAY SHOOT MORE INTO CARB..GETTING ANY JETS, ORIFICES ETC..FILL FLOAT BOWL AGAIN. P.S. CLEAN OR REPLACE AIR FILTER IF NEEDED! WAIT A WHILE, GAP NEW SPARK PLUG, INTRODUCE APPROX. 1-2 OZ. OF FRESH GAS INTO PLUG HOLE...QUICKLY RE-INSTALL SPARK PLUG ..WITH ON/OFF SWITCH-BAR OFF..PULL OR CRANK ENGINE A FEW TIMES. MAKE SURE IGNITION CAN FIRE, CRANK(ELECT. START) OR PULL STARTER ROPE & MOWER SHOULD FIRE OVER. IF IT STARTS..RUNS..THEN STALLS (AFTER USING UP GAS IN CARB, TRY IT AGAIN. IF IT CONTINUES TO STALL QUICKLY...YOU WILL NEED AT LEAST A CARBURATOR REBUILD, OR IF NO START AT ALL..YOU NEED TO SEE IF PLUG IS FIRING.
Posted on Apr 05, 2014
Poulan pro lawn mower will start with pull. Will NOT start with KEY
Take key switch out and look for damaged or broken parts or replace switch.They will come with new key.
Jun 11, 2016 | Poulan Pro 22inch 625 Series Briggs ...
I have recently bought a poluan pro mower. It has been spitting oil in filter and blowing out white smoke from muffler.
sounds like it is overfilled with oil remove oil fill to level line for motor but white smoke means its getting to much gas or is this two cycle engine wich would mean you mixed oil and gas wrong and to make another batch
Sep 22, 2013 | Poulan "Poulan" Push Mower
Poulan pro 650 model#96142003403
the easiest way is to run it out of gas and turn the mower on its side with the dip stick tube on the lower side and drain it from the dip stick tube
Jun 30, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I have a Poulan Pro 650 model. I need to flush the fuel line because I think the gas I put in it is bad. I no longer have the manual so I don't have any instructions. Does anyone out there have any...
First step is to take the gas cap off and tip the mower to pour the old gas out. Leave the cap off for awhile and let the rest of the gas evaporate. After you have handled this, pull out the spark plug and pull the started a few times. This will push whatever gas is left in the carb and lines into the cylinder where it can evaporate or spill out of the spark plug hole.
Jun 02, 2011 | Poulan Pro 22inch 625 Series Briggs ...
I just purchased a poulan lawn mower at Kents. Have not used yet. Can you add unleaded gas to the poulan lawn mower/do you have to mix the gas?
James
May 22, 2011 | Poulan "Poulan" Push Mower
What type of fuel do I use in my push Poulan Pro lawn mower, reg. unleaded gas or mixture. I have been using mixture and mower is running sluggish. Want to know if I am using the right fuel.
Mar 11, 2011 | Poulan Garden
Need to put oil in and don't know what kind of oil to put in or if it's gas oil mix????
ADD SAE 30 SMALL ENGINE OIL. 18oz TO 20oz
SEARS SALES A 20oz BOTTLE OF CRAFTSMAN SAE 30 OIL FOR $2.59
Oct 12, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
PP 22inch 625 series 190cc - What Gas/Oil mix should i be using?
I think your mower has a 4 cycle engine. That means the oil goes in the crankcase and the gas goes in the gas tank. No oil mixing needed! If you look at the top of the mower you should see two caps. Each one will be marked with what goes in them.
The oil should be 30 weight non-detergent oil. Available at your local car parts store or Lowes or Home Depot.
Gas is just plain old pump regular.
Oct 09, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Poulan Pro " Pro" Self Propelled Mower Logo
104 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
