Question about KitchenAid Superba Series KUDE70FXSS Fully Integrated Dishwasher - Stainless Steel
How much is a new circuit board for kude70fxss?
How much is a new circuit board?
My black and red wires for my nds speaker circuit boards was severed. Can they still be used or do I need a new circuit board?
If the board (PCB) is not damaged you can re-solder the wires back. If the PCB is damaged you should be able to get new ones by looking up the make and model of the device and look for the specific part.
Aug 07, 2015 | Nintendo DS Video Game Consoles & Games
Kitchen aid dishwasher stopped mid-cycle and won't drain. Can't re-start. Suspect clogged drain.
This blog might help: http://www.applianceblog.com/mainforums/threads/24574-Dishwasher-stopped-mid-cycle
Mar 10, 2015 | KitchenAid KUDE70FXSS Builtin Dishwasher
Kude70fxss check valve
After the wash the drain valve must be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 11, 2012 | KitchenAid KUDE70FXSS Builtin Dishwasher
Kude70fxss
Do you still have water down the bottom of the unit? Usually when you are hearing that pump noise that is from the drain pump and the reason it is constantly running is usually because there is an obstruction either blocking the hose or blocking the pump from evacuating all the water from the unit. This is a fairly common issue on all dishwashers. Remove the spinner on the inside of your unit and assure that there is nothing blocking the port exit hole. If there is not then you will have to de-install the dishwasher and pull the unit out and remove the drain hose to assure nothing is stuck inside the hose and at its connection point usually to the disposal under your sink. Remember to turn off the water as well as the power before you de-install. If you have any further questions message me back. I await your reply
Thank you,
Rick
Jan 10, 2012 | KitchenAid KUDE70FXSS Builtin Dishwasher
The control lock light is on my KitchenAid dishwasher KUDE70FXSS... I called for help and the hotline told me I need a technician to come out! How can that be? The dishwasher is brand new and I simply...
Hello & Welcome to FixYa
Press and Hold the HEATED DRY/NO HEAT DRY button for 20 seconds to unlock the control. Please get back to me if you have any other questions.
Kevin
Aug 26, 2011 | KitchenAid Dishwashers
The circuit board on my 9 year old neptune washer went up in smoke. Do I replace the circuit board or by a new washer? Thank you!
Check the price of a new circuit board against the price of a new machine. Take into consideration that installing a new circuit board yourself might see the new one go the way of its predecessor due to some other fault. Have a qualified technician give you a quote on the repair and again compare prices.
Jan 25, 2011 | Maytag Neptune Washer
It seems that the fuse for that board has blown how or where can I replace that circuit board
I don't know if WD are like Maxtor but M won't supply you with a replacement pcb - they want you to buy a new drive.
If you can find an IDENTICAL WD drive buy it. Take care and remove the circuit board from the new drive. (It's very straightforward). Now remove the circuit board from the duff drive and replace it with the board from the new drive.
Plug it in and test. Does it work? Does it mount?. Now copy all the data from the drive onto something else as a priority. Once you have completed the transfer, remove the drive, remove the circuit board and refit it to the new drive. Mount the new drive, format it and then copy all your files back again.
Use the new drive and keep the old for safe-keeping.
The only thing that can go wrong (other than being ham-fisted) is that there is a problem with the old drive that has caused the fuse to blow and it could well cause the fuse in the new Circuit board to blow. But that's a chance you've got to take if you want your data back.
Sep 22, 2009 | Western Digital Caviar SE WD2500JD 250 GB...
Braun QS3 Range Hood
The circuit board that we use to replace the old ones are a new generation of circuit boards. To this day i have never had to replace a circuit board that i had already replaced, and beleive me i replaced a fair share.
Jun 13, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Connection of new circuit board to creda tumbe dryer TVR2
Nee
d more info. Need dryer brand, model and serial numbers.
Nov 09, 2007 | Dryers
KitchenAid Superba Series KUDE70FXSS Fully Integrated Dishwasher - Stainless Steel Logo
13 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
