Question about 3Com 4500 24-Port Ethernet Switch
How can i access it using telnet? - 3Com 4500 24-Port Ethernet Switch
If it allows telnet sessions, you would go to a command prompt and type:
telnet 192.168.1.2 (or whatever the IP address of the switch is.)
Posted on Jun 25, 2009
Access denied
yes, you should be able to connect to the console port using a roll-over cable RJ45-DB9, connect using hyper terminal or similar using the com port settings 9600,8,N,1
You can then configure the switch from the CLI...
Have you set the 'Login' command on the VTY lines in the switch setup and an IP address on the management VLAN to connect to.
You also HAVE to have a password enabled on the vty lines in order to connect via telnet.
hope this helps.
May 09, 2012 | Cisco Catalyst 2960-24PC-S Ethernet Switch...
Sun V60 box cannot be accessed remotely. os is Linux
What method are you using to try to access it? If you are trying to use SSH or Telnet, you will need an SSH or Telnet daemon running on the server. If you are trying to access it from a computer that is not on the same subnet, you will need to forward the Telnet or SSH ports through your router.
Apr 01, 2011 | Sunfire V60 V65 (x5132a)
I can't tune dhcp service on the AP WAP 610n, because the service is abcent. Does it have such function? And how to turn it on. Also there is no settings like telnet access, ssh access etc. The firmware...
probably not . It is a Wi Fi access point by the sounds of it .
what you need is an additional router between the AP WAP 610N and the modem to provide the DHCP which is a protocol that allows ip addresses to be automatically allocated to computers and devices. So you need a router with a DHCP server built into it. DHCP stands for Dynamic Host Control Protocol.
And the settings for telnet access, ssh access etc are protocols and you are most likely thinking of firewall settings which would most likely be in a router.
The firewall can control access to TCP/IP logical port numbers used by the telnet and ssh protocols .
Nov 28, 2017 | Linksys by Cisco WAP610N Wireless-N Access...
Adtran Telnet
Are you getting any failure msgs? Where are you telnetting from? Has your router been restarted? If you have web access turned on the router, you might be able to login via your browser, or you could directly connect to your router via a console cable to check your configuration.
Jun 23, 2009 | Adtran Total Access 850 Router...
Locked out of HTTP inside port on SG300 - telnet works
I was unable to supply a link to the manual for this product so I downloaded it to one of my sites to make it available to you. Here is the link:
http://www.dscmain.com/snaplink/sg_314_ug_revA.pdf
Please let me know if this helps...
Tim
Mar 23, 2009 | SG300 (SG0126US) Firewall
Not able to telnet to my home router (netgear WGR614V9)
You have to have telnet access enabled for all earlier revisions of wgr614. See : http://www.seattlewireless.net/index.cgi/NetgearWGR614#UnlockingtheTelnetCosole but bear in mind that v9 is not known officially to have a telnet CLI.
Cheers,
Mar 17, 2009 | NetGear Computers & Internet
Cannot telnet to SN0108 altusen serial over net
Please change the ip address to 192.168.1.32 or something and try telnet.  Thanks ,
Vipin
Mar 16, 2009 | Altusen 8PORT POWER ON THE NET W/ (PN0108)
Connection problem using telnet and web...
Not a definite solution but there are two things you can try.
Firstly, disconnect all cables and power supply to the router and leave it switched off for a minimum of 10 - 15 mins.
Reconnect everything and wait until all the lights on the router stop flashing.
Finally, go to the wireless icon on the toolbar, rick click and select "repair". This will reset the wireless adaptor.
Good luck.
Mar 05, 2009 | Linksys Wireless-G WRT54G Router
Troubleshooting
Telnet is an application layer protocol. If you can telnet to the other router, then you do not have any network issues. However, the fact that you can telnet but not ping suggests that icmp messages have been blocked in the configuration of one or both routers. This is a security feature, because attacks can be launched via icmp messages.
Apr 18, 2008 | Computers & Internet
Computer
On the controlled pc you must open administrative tools - services and make sure telnet service is started and set to automatic.
On the controlling machine, open a dos window and type "telnet computer-name" or "telnet ip-address" when prompted enter username and password that is valid on controlled pc, at that point you can run many dos command line commands and programs. Make sure that controlled pc has passwords for all accounts, otherwise you open a big security hole.
Apr 06, 2008 | Microsoft Windows XP Professional With...
Open Questions:
3Com 4500 24-Port Ethernet Switch Logo
824 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
