Question about Garden
Murray 10 hp model no 309029x92 won't start what might cause this problem. Battery is charged.
2 Suggested Answers
lemmingleejn
  • 173 Answers
SOURCE: murray riding mower
You may have to change the magneto.
That's the return circuit which charges the battery.
Posted on Jul 27, 2009
Murray riding lawnmower #309029X92 can't turn shaft, Won't even start,
Karen, try to spin the top of the engine by hand. it should rotate, if it don't check to see if the starter has locked into the flywheel. make sure the blades are disengaged the brake pedal is pushed in and you are sitting on the seat.
May 30, 2016 | Murray Garden
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Murray B&S 13.5HP turns over but won't fire.
What is the integrity of the fuel in the unit? Is it over thirty days old? Is there water in the fuel? If you remove air cleaner and spray carb cleaner and crank, what happens?
Jun 20, 2013 | Yard Machines Garden
My 12.5 hp 40 in cut murray won't start worked fine last winter when i put it up i've replaced the battery n plug an still won't make a sound
Check the ignition coil for spark if it does not make sure the ground wire that runs to the brake is releasingn if it is replace coil
Apr 01, 2013 | Murray Garden
Murray 42 in 17 hp doesnt start
i would look at the safety switches that being the most common cause
Jun 16, 2012 | Garden
I have a craftsman LT 1000 lawn mower that runs the battery down while it sits and it will not charge the battery while mowing even though the guage says that it is charging.
Something within the machine is discharging the battary, it does not sound like the engine is not charging, there is a tool called a negative shunt, it connects to the negative pole on the battary and enables you to connect a multi meter, this will tell you if there is a charge going out of the battary when the machine is switched off, you can then disconnect components to see which one is causeing the problem, a good mower shop should have such a tool .
Mar 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray riding mower
Jul 26, 2009 | Garden
Murray 17.5 HP mower - no noise when turning key? Maybe ignition?
Look near the starter solenoid for a fuse. It is probably under the hood near the steering column. If fuse is good, problem is likely a safety switch.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MURRAY AUTOMATIC DRIVE, 42" CUT, 17HP, TWINII,MODEL 42A707,TYPE 2653E1,CODE 9710235B. Battery fully charged,starter will not turn fast enough to start engine. acts as tho there is a presure build up....
Dropped / Stuck valve?
Major Overheat?
Battery weak (understand it is fully charged... but is it delivering proper amperage under load?)
bad connections betwixt battery and solenoid, then solenoid to starter?
Weak starter motor?
Mar 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
