Question about Brother MFCJ4510dw Color Inkjet All-in-One Printer
Why doesn't Brother MFC-8910dw paper auto select detect paper in MP tray?
SOURCE: MFC 8660DN
"MP" means "Manual Paper" Tray. Is paper in the manual paper tray or the main tray?
Posted on Jun 14, 2008
komguy
  • 2306 Answers
SOURCE: Paper is in the feed tray, but it continues to say
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Posted on Nov 06, 2009
xptareq2000
  • 1447 Answers
SOURCE: I have a brother MFC-9440cn printer. The printer
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Posted on Jan 14, 2010
GodBlessU
  • 3513 Answers
SOURCE: I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Posted on Jan 15, 2010
kphormel
SOURCE: Brother MFC-9840CDW says no paper when trying to
I had the same problem and in trying to troubleshoot it, I found out it was getting "No Paper" with just one Word document. I went into "Page Setup" and then "Page" for that document, found paper sources were set to "Manual", changed them both to "Page 1", then re-sent document to print and it worked!
Posted on Oct 24, 2011
How to correct a Paper Jam message, when there is no paper in unit(printer)
First up, put paper in it. A failed pick up also registers as a paper jam. Run a test page and find out WHERE the paper feed stops. If the paper does not feed - Clean the primary pick up roller at the Front (usually) that takes paper from the cassette. Please not some of the larger machines have the pick up roller inconveniently placed at the back of the tray cavity
Mar 15, 2016 | Brother International Brother MFC-8910DW...
MY BROTHER MFC 9440CN KEEPS SAYING NO PAPER RELOAD PAPER IN MP TRAY
not sure if your on copy mode or print mode ..close the MP tray door....turn off then on go to general setup select tray 1. not sure if your on copu mode or print the machine wants you to add paper to the tray that needs it. if you add paper dowes it still say"add paper" .if this is the case then the tray sensor is 1)broke2) pushed out of the way folded3) tray feed roller are not installed correctly no allowing sensor ..make sure your printer settings(properties) are set the that tray.
Oct 16, 2014 | Brother MFC-9440CN Laser Printer
Have changed setting to tray 1 instead of mp tray and printer will not change and still says no paper
Sensor that detects paper needs to be replaced. Same thing happened to my machine and I had to take it in to a Brother repair company. 1 hour service call
Jul 07, 2014 | Brother MFC-8460N All-In-One Printer
Trey 1 is giving a message out of paper when they is paper inside
The message "No Paper" will appear on the LCD display if the Brother machine does not detect paper in the paper tray(Tray#1 or Tray#2) or MP(Multi-purpose) Tray.
Resetting the Brother machine may resolve this issue. To reset the machine, unplug the power cord from the AC power outlet for approximately 10 seconds and then plug it back in.
Note
For MFC users :
The Brother machine can be powered OFF for up to 4 days without losing faxes in memory.
If the message "No Paper" continues to appear on the display follow the instructions listed below:
When printing from Tray#1 or Tray#2 :
Pull the paper tray completely out of the machine. Go to STEP2.
When printing from MP Tray :
Go to STEP4.
Note Tray #2 is the optional LT-5300 paper tray.The MP Tray is just above the main paper tray and can be accessed by opening the MP Tray door. To open, pull on either the left or right side of the front door by the circular cut out.
2. While pressing the blue paper-guide release lever, slide the paper guides to fit the paper size. If the back of the paper tray doesn't move, the tray lock button may be in the lock position; slide the lock button to the unlock position and pull out the back of the paper tray again. With the paper removed, you will see the LTR (letter) marking on the plastic plate on the bottom of the paper tray to indicate where the moveable rear guide (with protruding arrow) should be moved to for letter size paper. There is also a marking for legal size paper. Make sure the guides are set at the correct mark. Reload the paper in the paper tray. Make sure the moveable rear guide does NOT push tightly against the paper. It should be adjusted to the LTR (letter) or LGL (legal) position, depending on your paper size. If the moveable rear guide is pushed too tightly against the rear edge of the paper, the paper will get stuck in the tray and a loud plastic snapping noise may be heard when feeding paper.
3. Move the tray lock button to the lock position (slide the button towards the paper).
4. If there is no paper in the tray, reload the paper.
The tray can hold up to 250 sheets of 20lb paper. Do not overfill the tray. There is a maximum paper mark located on the top of the right and left paper guide. It looks like a V cut out in the plastic.
Note
If you are using special paper and the machine has problems feeding it from the paper tray, try the paper again using the manual feed tray. Make sure you insert the paper far enough --about 1 inch- under the gray plastic bar in the MP Tray until it stops or it will not be fed and the machine will display the message "No Paper".
5. Verify the correct size and type paper is being used:
If you are printing from a PC and using the paper tray, make sure that MP Tray is NOT selected in the application's print properties for Paper Source.
If you are printing from a PC make sure that the MP Tray is selected in the application's print properties for Paper Source.
Note: Please be aware that the setting in the printer driver will take priority over the setting made on the control panel.
14. If you have set the Tray Use settings for a particular tray, the machine will feed paper only from that tray. If the selected tray is out of paper, a "No Paper" message will appear on the LCD. You need to reload paper in that tray.
To set the Tray Use setting, follow the steps below:
a. Press Menu.
b. Press the up or down arrow key to select General Setup.
c. Press OK.
d. Press the up or down arrow key to select Tray Use.
e. Press OK.
f. Press the up or down arrow key to select the mode you want to use.
You can select Copy, Print or Fax(MFC users only).
g. Press OK.
h. Press the up or down arrow key to select the tray.
You can select Tray#1 Only, Tray#2 Only or MP Tray Only.
i. Press OK.
15. For MFC users :
To test, print the Help List.
. Press Menu.
a. Press the up or down arrow key to select Print Reports, and press OK.
b. Press the up or down arrow key to select Help List, and press OK.
c.Press Start.
For DCP users :
To test, print the User Settings.
d. Press Menu.
e. Press the up or down arrow key to select General Setup, and press OK.
f. Press the up or down arrow key to select User Settings, and press OK.
g. Press Start.
Note
If the problem still continues after following the above instructions,
I recommend you clean the Separation Roller, Pickup Roller and Separation pad following the instructions of the FAQ: My Brother machine mis-feeds paper.
Apr 21, 2012 | Brother MFC-8460N All-In-One Printer
BROTHER MFC-8460N / After inserting paper tray the machine will not pick up paper. There is a clacking sound & an error message: no paper
Try this out.
1. Page Setup
Paper
(Paper source) - First page: Auto Select; Other pages: Auto Select
2. Print
Properties
Paper/Quality - Tray Selection (Paper source): Auto Select
Regards,
Shawn
Jan 31, 2011 | Brother MFC-8460N All-In-One Printer
NO PAPER MP
Thanks
Jan 15, 2010 | Brother MFC-8640D Printer
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
MFC 8660DN
Jun 03, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Brother MFCJ4510dw Color Inkjet All-in-One Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
