Question about Home
What type of metal is underneath the coated enamel roasting pan
What type of metal is underneath the Mainstay coated enamel roasting pan. If the pan should get scratched to the metal underneath the enamel; I would like to know what material will be exposed. Is it safe to use a scratched enamel coated roaster?
Noggin
  • 944 Answers
SOURCE: Non-stick surface damage
Contact these guys and they should be able to supply replacement grill plates cheaply; http://www.esalton.com/control/contactus In general the current view is that low quality aluminium alloys, when used for cooking can put enough aluminium into the food over a long period of time to POSSIBLY influence certain conditions such as alzheimers disease, amongst others. There is a certain amount of aluminium in many things we eat or drink, regardless of what it is cooked in. If you use the grill every day then i would recommend replacing the plates, especially if the aluminium itself is becoming pitted, however I have used similar, lower quality grills before with coating worn and haven't gone mad yet. If in any doubt then replace the plates, but i think you are being over cautious here. If you find that food is now sticking to the grill, try grilling half a handful of salt with a little vegetable oil for 10 minutes or so, spread over the whole plate - a certain amount of "non-stick" can be achieved like this, although if cleaning the plates with detergent, this will soon need doing again. Hope this helps :)
Posted on Mar 27, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: my microwave turntable is scrubing
The floor will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
I would then leave the door open to let it dry untouched overnight.
You didn't mention your oven's brand or model, but it may be that the wheels on the turntable support are worn or there may grease built up in the axles.
Or you may need a new turntable support.
If you need to order a new one, please reply back with your brand and model number so we can help point you to the proper distributor.
Posted on Jan 03, 2009
SOURCE: Regal bread maker K6725
Where can i buy a drive belt for a K6725 kitchen pro?
Posted on Feb 14, 2009
erpaalai
  • 999 Answers
SOURCE: COATING ON INSIDE OF MICROWAVE HAS STARTED TO COME
Nothing special in there. As long as the paint is not flaking into the food you are ok, Be aware that bare metal could begin to arc. There is special microwave paint available but it will not match and look bad unless you redo the entire interior.
Eric
Posted on Sep 15, 2009
muttandjeff
  • 359 Answers
SOURCE: I am exploring the idea to install wire mesh on my
thin set mortor available @ home depot, lowes or any buielding supplier
Posted on Jan 05, 2010
Should I put water in the lower roaster pan that is underneath the removable pan?
Yes, a little water helps to keep your roast from drying out. You can also chop up some root vegetables into large dice as well and put them under there. Carrots, parsnips onions celery are all good. The roast juices fall on to them, make a fantastic gravy and also delicious on the plate. I do this often and the results are great.
Feb 07, 2016 | Nesco 18 qt Nonstick Roaster Oven
Which is the best jellyroll pan for sponge cakes?
You can try Chicago metallic commercial jelly roll pans, they are perfect for making sponge cakes and much more.
Jul 29, 2015 | Home
Black (rust colour) stains in the carafe
The fact that is is a stainless steel container makes it highly unlikely that it is rust. You should never drink out of a rust container. I would suggest a highly caustic but non-toxic cleaning agent. I'd start with vinegar or lemon juice. If you can get your hand in there, let it sit for a while and give it a scrub. Steel wool would definitely get the nasty stuff off but may also compromise any type of protective coating so inspect the metal to see if it has any type of coating over it (like an enamel glaze) should be bare stainless though.
Apr 16, 2014 | Trudeau Lyra Stainless Steel Carafe
Peeling nonstick coating
It can't be fixed. In the future, use only plastic cooking utensils so they won't scratch off the non stick coating. You can line the pan with foil if it is a baking pan, if it's a frying pan, there's no fixing it.
Apr 07, 2014 | KitchenAid 16-Inch by 13.5-Inch Roaster...
Should I cover my roasting pan or not?
when using a roasting pan, it depends on the type of meat and the recipe if you should cover the pan or not.
meat with a high fat content eg duck doesnt need to be covered.
lean cuts should be covered when roasted for a long time to keep the juices and soften the meat.
May 06, 2013 | Home
What are roasting pans made from?
They can be made from aluminim foil (disposable pans), stainless steel, coated enamel, cast iron, or clay.
Jan 14, 2013 | Home
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
We have a Reliance 501 (40 gallon) natural gas water heater Model 5 40 NORT0 Serial F94799798. Does it have a glass liner?
Your Reliance serial number shows your water heater was made in July 1994.
Except for the Marathon water heaters, and copper-tank water heaters, all tank-type water heaters are made of steel. That steel has an enamel coating which people call a glass liner.
So in that sense, there is a glass liner.
See a photo of the liner:
http://waterheatertimer.org/images/Enamel-coated-steel-290.jpg
Also inside the tank is an anode rode.
The anode is made to protect the steel tank.
Anode is made from lower noble metal than steel, so water reacts with the lower noble metal first.
The water eats away the anode rod instead of rusting the tank.
Once the anode rod is gone, the water begins rusting the tank.
The enamel coating does not protect the steel from rusting.
The tank rusts away and begins to leak.
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Nov 01, 2010 | Reliance Natural Gas Water Heater Control
Microwave enamel wearing away
It will have to be sanded smooth and clean and dried thoroughly.
Enamel should work, but appliance paint is better.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 20, 2008 | GE JVM1650 1000 Watts Microwave Oven
Home Logo
220 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
