Question about Konica Minolta bizhub C250 All-In-One Laser Printer
What does konica 6500 error code c-2833 mean?
  • Konica Minolta Master
  • 6,161 Answers
Cyan drum sensor issue.
located behind the drum each drum has one.
Posted on Dec 29, 2015
2 Suggested Answers
  • 44 Answers
SOURCE: error code c-2833
CAUSE: LD Power becomes saturated when performing Auto Gamma adjustment in a low humidity condition.
SOLUTION: Perform the following adjustment:
1. [Utility].
2. [Machine Admin. Setting].
3. [System Setting].
4. [Expert Adjustment].
5. [Process Adjustment].
6. [Toner Quantity / Exposure].
7. Select the proper Exposure Adjustment [Yellow, Magenta, Cyan, or Black] by using the Next/Previous button.
8. Select Standard then select [-2] under Exposure.
9. Press OK.
Notes:
a. If the problem persists, replace the problem color drum since the cause of the SC is the combination of drum characteristic and humidity.
b. The following codes = colors: C-2831 = Yellow; C-2832 = Magenta; C-2833 = Cyan; C-2834 = Black.
Posted on Dec 07, 2009
How can i do for error C6702
http://www.copytechnet.com/forums/konica-minolta/30879-konica-minolta-biz500-code-error-c-6702-a.html
guy does eventualy fix it on later pages
worth a good read
i got board half way down
a good tip with rollers {rubber not sponge} is too use white vinegar wipe it on leave it to dry
and run few some fully black sheets...prints
then it works magic
Dec 09, 2014 | Konica Minolta Bizhub C 6500 Copier
How do you correct error code 2833 on a konica minolta bizhub 6500
Remove the Cyan Drum, once done you will see a small chrome/silver bar near the front of where the drum will be the small silver strip has small tiny little square on it inside that square is a sensor, use a small clean brush and clean it, recommend you might do all four of them. That sensor monitors the drum for certain voltage settings,
Jun 25, 2014 | Konica Minolta Office Equipment & Supplies
What does error code c3102 0n a konica minolta bizhub 6500 mean
problem with Fusing release home sensor and or fuser motor. Fuser is the Hot Part of the machine
Jun 16, 2014 | Konica Minolta Office Equipment & Supplies
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
Error code c2863
Hi, i have a konica minolta c6500, and i have a problem with error code c-6500. What happen?
Mar 26, 2013 | Konica Minolta bizhub Office Equipment &...
Error code c-2833
1. [Utility].
9. Press OK.
Notes:
Dec 03, 2009 | Konica Minolta bizhub C250 All-In-One...
What does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Jun 08, 2009 | Konica Minolta Office Equipment & Supplies
ERROR CODE C-4401 On Konica Minolta Bizhub 500
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
Feb 19, 2009 | Konica Minolta Office Equipment & Supplies
Error code f-51-6
this is your WRITE UNIT CODE.''''PRIT HEAD''''
you chould try to reseat all connectors ,and especially the write unit ,how handy are you?????
let me know
Oct 23, 2008 | Konica Minolta Di1610 Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
718 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
