Question about Dymo LetraTAG Thermal Label Printer
Why doesn't it print - Dymo LetraTAG Thermal Label Printer
Doesn't print correctly, the film doesn't go where it should
Hello Carlo,
When you say your printer doesn't print correctly, could you give some more details? What is the problem with the printing?
Also, could you may attach a photo / card scan which shows the problem? The internal test card would be best (press the small test button on the rear of the printer.
Regards,
MC.
Jan 29, 2013 | Magicard Rio Card Printer
HP 5150 Deskjet -- black printing abruptly stopped. Prints appear with color but no black. Switching black cartridges doesn't help. Clean print heads operation doesn't help. Switching computers...
There are very few things you can do, other than what you have aleady done.
I would recommend a decision on how much the unit cost and how long you have used the
printer vrs. what HP or a local authorized service center would charge to repair it.
If you have refilled ink cartridges, this is problem that can arise due to ink drying on the
print head as the black cartridge is use the most.
Aug 06, 2011 | HP DeskJet 5150 InkJet Printer
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
My printer doesn't print word documents (it doesn't print in black, but it does in colour), it prints everything else. I already checked the port (it's USB), changed the cartridge, uninstalled...
try the following
1.power on your peinter
2.while press and hold the power button ,open and close the top cover times.
printer pick the paper and print the test page and alignment pattern for black and color.
if any of the black or color alignment pattern is not print ,then u have to change the cartridge accordingly.
Aug 01, 2011 | HP Deskjet D2360 InkJet Printer
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
Epson stylus photo r300 removed print head, flushed out all nozzels with water, dried everything, reasembled everything, including the flat ribbons, two different times. After dozens of times trying to...
If an inkjet printer has not been used for some time and several print head cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 24, 2011 | Epson Stylus Photo R300 InkJet Printer
It wont print but it doesn´t report no errors, it just doesn´t print
data cable connection may be loose
fix it properly or
change the data cable
Aug 12, 2010 | HP DeskJet 710c InkJet Printer
Doesn´t print at all
The cartridge is defective. Replace with BC-10 high capacity Black, or BC-11e Color.
Mar 17, 2008 | Canon BJC 80 InkJet Printer
Not printing on last copy
My guess is it?s probably the print head. These things are designed to print on single sheets so even though it?s probably well within specs it still doesn?t have enough force to push an image to the last page. Less likely but never the less a possibility this could also be caused by inconsistent paper in the two boxes. Continuous feed, multi-part forms in a box are made by several manufacturers and have different characteristics. -You might try flipping the box of forms from the printer that works to the one that doesn?t just to make sure it?s not the forms. When I used to use multipart forms we would place orders for several boxes of the same form and occasionally some would be from a different manufacturer. The paper looked the same but the characteristics were way different. By the way we tried to do four-part but could never print beyond three part forms. Our fix was that we decided we only needed one in-house copy. -If the problem doesn?t follow the paper then I would suspect the print head. Panasonic print heads are fairly easy to replace and fairly inexpensive so I would try changing it out. With a lot of use the print heads do wear out so even if this doesn?t solve this problem you?ll have a spare when your vertical characters start looking wavy?. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 14, 2007 | Panasonic KX-P2023 Matrix Printer
Dymo LetraTAG Thermal Label Printer Logo
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
