Question about Hoshizaki Commercial Freezer KM-500MAH
Ice machine keeps freezing on the ice trays - Hoshizaki Commercial Freezer KM-500MAH
  • Hoshizaki Master
  • 1,252 Answers
If you are referring to the ice not clearing the evaporator plates, usually the defrost cycle is too short. Check that by watching the machine and when it goes into the harvest mode, see if all the ice comes off. If not, lengthen the cycle.
Posted on Jun 17, 2017
My Ice maker doesn't make ice anymore
90% of ice maker problems are water related. Sounds like water may be continually seeping in from the inlet water valve (normal thing to do if the water level is low). This will not allow the water to get down to freezing temperature. You have to identify the reason that water is constantly running in. It's probably "leaking" out at the dump valve. Or does that unit have a float valve that may be leaking. Check your drain to see if water is leaking out during the freeze cycle.
Jul 07, 2014 | Hoshizaki Freezer Commercial Ice Machines...
I have a manitowoc commercial ice machine.It has stoped making Ice and just seems to keep running water and not freezing
Check to see if the compressor is running... if it is running and not cooling then it may have a refrigerant leak...
If the plate is getting cold but the water is not freezing then check to make sure that the float is not stuck on and the the water just keeps running in... that will keep the water warm enough so that it does not freeze...
heatman101
Mar 10, 2011 | Freezers
My ice machine model f-450 mah makes ice but once it's full the water keeps running and runs out of the machine how do I fix this?
Make sure the plug in the water tray is secure and not allowing water to drip out. Check to make sure the float turns off the flow water once up to level.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
It beeps 3 times then pauses then beeps 3 times then pauses. Keeps this pattern
Unit was in the freeze cycle for 60 minutes and the freeze back up timer took over the process. In most all cases, either a stuck float switch or a leaking water valve.
Hope this helps.
Sep 25, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Running but no ice
if you are getting 5 min freeze cycles the first place to look is the Check valve this is the white triangular housing right above your pump motor it has three stainless screws take this out there is a spring and a seat clean the seat off and then stretch the spring lightly not too much replace and see if this solves the problem.
May 28, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
Bin control
The bin control shuts it off when the ice bin is full. Without a bin control it should keep making ice and never stop.
Dec 27, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Sub-Zero Under Counter Ice Maker not making Ice
ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Feb 20, 2008 | Freezers
Hoshizaki Commercial Freezer KM-500MAH Logo
91 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
