Question about Garden
Water mixing with pump oil - Garden
  • 32 Answers
Hi, you have not said what type of machine you have, but when this happens it could just be a oil seal in the pump,not a pressure seal.
could be a worn piston.
Posted on Jul 04, 2009
I have water in the engine oil. Could it be a water pump seal or a blown head gasket?
When you say that you have water in engine oil, do you mean that you have coolant mixed with oil ?
In order to determine if it's a seal or head gasket, you will need to perform a few tests. Cylinder leakage test on each cylinder can be done to determine if the head gasket is bad. When it comes to the water pump seal, if this was the problem, the coolant would not be mixing with the engine oil.
Nov 24, 2016 | Cars & Trucks
Why engine oil and water mixed in mazda3
Um, most likely not good. Most likely means the block is cracked allowing the water and oil to mix. Major engine repair.
May 16, 2016 | Cars & Trucks
Comet tw 5050 mix oil and water
what you have is a bad seal or a crack within the pump crack more common if any water was left in it during the cold winter
Jun 22, 2012 | Comet Pressure Washer Tw5050 Triplex Pump...
How to fix antifreeze from mixing with oil friend says it needs a little rubber piece. But not sure
It sound like it is the water pump is bad the only way coolant and oil can mix is at the water pump seal
Aug 23, 2011 | 2009 KTM 65 SX
Oil and water comming out of oil filler stem
You have a seal on the pump between the pump and the water pump thats leaking you have oil and water mixing . I owen three mechines and i don't understand what you mean when you say the oil filler stem. I also rebuild power washers and pumps. If you can clarify where the water and oil mixture is comeing out then i can tell you excatly what the leak is thanks
Jan 09, 2011 | Comet BXD2527 Pressure Washer Pump
1993 camaro V6 3.4 lt water and oil mixing could it be water pump
Yes there is another way, someone can be messing with your head and pouring water in your oil cap. Do have water in your oil or oil in your water or both? A product called sea foam does a miraculous job at getting water out of oil. As far as keeping it from happening further, the cheap way of course is "bar's stop leak" but man can this stuff do a number on clogging your heater core, even if they say it doesn't, it can happen.
Jun 07, 2010 | 1993 Chevrolet Camaro
I have a Comet 4040 and oil and water mix is bubbling out of the red cap on top of my pressure washer. Can anyone tell me what repair kit I might need to fix this problem?
Hi this could be the oil and pump seals worn. Also make sure that you don,t have the transit plug in or the pump cannot breath. It should have a air vented dipstick.
May 21, 2010 | Comet GXD2527G Pressure Washer Pump
Fuel mix in jetski is to oil rich need to lean out mix. Can start and run machine on trailer with hose attached, but upon putting ski in water seems to lack power to drive ski and stalls out. oil can be...
Jet ski's do not have an adjustment on the oil pumps unless they are cable operated. Most just run off the end of the crankshaft. If the machine sits for a while and the oil pump seal is leaking. Oil will collect in the crankcase and take a few minutes of running to clear out. You can live with this, replace the pump, or block off the pump and pre-mix. A popular, cheap solution but a pain when it comes to refueling. As for the lack of power you probably have water corrosion in your carburetor nothing a simple cleaning won't cure.
Jan 27, 2010 | Yamaha 12V Air Pump
Water leak/mixing with oil
change the seal behind the water pump impeller
the shifter shaft seal will stop leaking
if it continues to mix water and oil you will have to change the head gasket
Mar 10, 2009 | 2002 Yamaha YZ 426 F
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
