Question about General Electric GE Industrial Dept. TM2020CCU Main Breaker Load Center
I have a 17 year old home with a GE TM2020 Mod.1 K639 that I need to replace the front panel and door. Does anyone know where to find one? I ordered what I thought to be a replacement from Amazon and it will not work. The newer TM2020's were reconfigured and will not fit my box. Any solution would be apprieciated.
2 Suggested Answers
SOURCE: I have an older GE
I need an interior panel and door for a GE tm 2020 k342 mk1. If you do the swap can I buy your old interior panel?
Thanks-rub2raceatyahoo.com
Posted on Mar 15, 2011
How to calculate modulus
This calculator does not support the modulus operation directly, you have to simulate by a divide followed by a subtraction and a multiplication. Suppose you want to calculate 256 mod 17:
  1. Key in 256 [÷] 17 [=] and get the result 15,0588...
  2. Note the 15 in front of the decimal separator and key in [−] 15 [=]
  3. Get the modulus: [×] 17 [=], result should be 1.
Jan 14, 2011 | Casio FX82MS Scientific Calculator
I have an older GE TM2020 box that I want to upgrade to a TM3220 or TM4020. Will I have to buy a new breaker module, etc.? Can I throw in a larger GE panel in the existing box? Thanks
Nov 14, 2010 | General Electric GE Industrial Dept....
Ice forming on the back of side by side 17 yr old fridge
You have a bad defrost heater . To access , you will have to remove the inside rear freezer panel . The heater is located at the bottom of the coils . Take your model number when ordering the part so you get the correct part .
May 02, 2010 | GE Refrigerators
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
NEED TO KNOW HOW TO TAKE THE DRYER APART TO FIX IT
serviced from the front, open the door and lood at the rim of the opening the should be 2 phillips screws holding the main top assy down, after removing the top youll find 2 more screws securing the front panel
Mar 07, 2009 | GE Dryers
NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
Jan 19, 2009 | Sub-Zero 561 / F
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Nov 12, 2008 | GE WBVH6240F Front Load Washer
GE over the range Microwave shutting off
This is often due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown in the photo here:
http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
You say this is only 2 years old? I thought these models were much older... GE may cover it, but you'll have to contact them.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 08, 2008 | GE JVM1650 1000 Watts Microwave Oven
General Electric GE Industrial Dept. TM2020CCU Main Breaker Load Center Logo
66 people viewed this question
Top General Electric Electrical Supplies Experts
hpgwva
Rob Bridges
Level 1 Expert
ken skalski
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
