Question about Franke Saphira Espresso & Coffee Maker
Crankier shaphira troubleshooting - Franke Saphira Espresso & Coffee Maker
Need to know how to put the volume on the desk top of the computer
Use a troubleshooters. Windows computers come with built in troubleshooters that can help you fix volume issues. Click on the "Start" bar, usually found on the lower lefthand screen. Click "Control Panel." On the control panel, click "Troubleshooting" and then "Hardware and Sound." From there, select the option "Troubleshoot audio playback." Your computer will ask you a series of questions that will help the troubleshooter determine the cause of your volume issue. In most cases, a volume issue can be fixed using Windows built-in troubleshooter.[
May 23, 2017 | The Computers & Internet
How do remove jammed master from the disposal unit on a risograph GR3770?
This model is pretty obsolete, finding someone to service it will be difficult, and most will only promise to attempt it and not warranty the work, never the less, its what I recommend. If you must attempt it yourself, I recommend a set of picks from Menard's (around $5 for a set, they look like dental picks) and an exacto knife and then cut the master free in small pieces.
most riso techs who are trained on these will do a partial disassemble. If this were an RZ or an EZ I'd be willing to try talking you through that. I don't recommend it if you're a novice on these though. They're much crankier.
Jul 14, 2014 | Riso Office Equipment & Supplies
Why can't I install download of Magix Movie Edit Pro 14 in Windows 7
You try try the compatibility wizard in Windows 7 to see if you can install Magix Move Edit Pro 14 in compatibility mode for Windows Vista.
To run the Program Compatibility troubleshooter
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
  • You can also open the Program Compatibility troubleshooter by right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility.
Feb 27, 2014 | Computers & Internet
Troubleshooter wizard not working
"Troubleshooter wizard?"
How about you just stating what the problem is..........
I won't go into detail, about what I think of the "Troubleshooting Wizard" (It would be negative thoughts, trust me...)
Post back in a Comment
Regards,
joecoolvette
May 03, 2013 | HEWLETT-PACKARD HP Mini-Notebook...
Bad print quality
Follow the steps listed below to print the PQ troubleshooting pages. These pages consist of one procedure page and five color test pages.
  1. Print a copy of this Web page and walk over to the printer you are troubleshooting.
  2. Load either 8.5 x 11-inch paper (letter) or A4 in Tray 2 popup_i.gif of your printer.
  3. Press the Menu menu_button.gif button to enter the MENU on the control panel of the printer.
  4. Press the Down arrow down.gif button to highlight DIAGNOSTICS.
  5. Press the Select select.gif button to select DIAGNOSTICS.
  6. Press the Down arrow down.gif button to highlight PQ TROUBLESHOOTING.
  7. Press the Select select.gif button to select PQ TROUBLESHOOTING.
  8. Pick up the PQ troubleshooting pages.
  9. Return to your computer to continue the troubleshooting procedure.
The message PRINTING... PQ TROUBLESHOOTING displays on the control panel until the printer finishes printing the PQ troubleshooting pages. The printer returns to the Ready state after printing the PQ troubleshooting pages.
Feb 17, 2011 | HP LaserJet 3600n Printer
I cannnot get my dell optiplex 360 to have sound. It had sound before and now it doesn't. I download the drivers on dell website and it still is not installing correctly or something.
Hardware Troubleshooter If a device is either not detected during the operating the system setup program, or is detected but incorrectly configured, you can use the Hardware Troubleshooter to resolve the incompatibility. For more information on using the system setup program, see the Dell Technology Guide on your computer or at support.dell.com.
Windows® XP:
  1. Click Start® Help and Support.
  2. Type hardware troubleshooter in the search field and press <Enter> to start the search.
  3. In the Fix a Problem section, click Hardware Troubleshooter.
  4. In the Hardware Troubleshooter list, select the option that best describes the problem and click Next to follow the remaining troubleshooting steps.
Windows Vista®:
  1. Click the Windows Vista Start button troubl69.jpg , and click Help and Support.
  3. In the search results, select the option that best describes the problem and follow the remaining troubleshooting steps.
Oct 26, 2010 | Dell OptiPlex 360 Desktop Computer
I have version 3.0 and windows 7 and it wont load. i see the start screen with the lady on it but nothing ever happens. I really want to use this program like i do on my other pc.
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
Sep 13, 2010 | Nova Development Photo Explosion Deluxe...
I have Adobe CS3 Master Collection and I am trying to install it on windows vista but it keeps asking for a sr .no
http://www.adobe.com/support/ultra/
this is right to there tech site ,
Troubleshoot installation problems in Adobe Ultra CS3 (Windows Vista) 2008/05/02 What's covered Overview Before you begin Beginning troubleshooting Intermediate troubleshooting Advanced troubleshooting Overview This document can help you to resolve system errors that occur while ...More > Troubleshoot installation problems in Adobe Ultra CS3 (Windows XP) 2008/05/02 What's covered Overview Before you begin Beginning troubleshooting Intermediate troubleshooting Advanced troubleshooting Overview This document can help you to resolve system errors that occur while ...More > Troubleshoot system errors or freezes in Adobe Ultra CS3 (Windows Vista) 2008/05/01 What's covered Overview Before you begin Beginning troubleshooting Intermediate troubleshooting Advanced troubleshooting Overview This document can help you to resolve system errors that occur while ...More > Troubleshoot system errors or freezes in Adobe Ultra CS3 (Windows XP) 2008/05/01 What's covered Overview Before you begin Beginning troubleshooting Intermediate troubleshooting Advanced troubleshooting Overview This document can help you to resolve system errors that occur while ...More > Ultra Creative Suite 3 Read Me
sorry you didnt say what operating system your using
but follow the top link the rest is what is on that page
Mel
Jun 07, 2010 | Adobe Computers & Internet
Hitachi 50v500 50"
the unit requires a replacment optic block to correct the problem your experiancing
if you are the original owner you may contact hitachi customer relations and they may opt to supply a remanufactured optic block and you would be responsible for the labor but still cheap enough and you get a good working set again
Jan 16, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Bios Beep code
Beep Code Manual, Better Than Gold Techies, American Megatrends Int. & Phoenix
(I'm IT, I use these codes to trouble shoot hardware issues at my job. Enjoy) cold.gif
BIOS Beep Codes
When a computer is first turned on, or rebooted, its BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, or if there is a problem with the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected. Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
The two most-used brands are AMI (American Megatrends International) and Phoenix.
Below are listed the beep codes for AMI systems, and here are the beep codes for Phoenix systems.
AMI Beep Codes
Beep Code Meaning 1 beep DRAM refresh failure. There is a problem in the system memory or the motherboard. 2 beeps Memory parity error. The parity circuit is not working properly. 3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory. 4 beeps System timer not operational. There is problem with the timer(s) that control functions on the motherboard. 5 beeps Processor failure. The system CPU has failed. 6 beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode. 7 beeps Virtual mode exception error. 8 beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card. 9 beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty. 10 beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS. 11 beeps Bad cache memory. An error in the level 2 cache memory. 1 long beep, 2 short Failure in the video system. 1 long beep, 3 short A failure has been detected in memory above 64K. 1 long beep, 8 short Display test failure. Continuous beeping A problem with the memory or video. BIOS Beep Codes
Phoenix Beep Codes
Phoenix uses sequences of beeps to indicate problems. The "-" between each number below indicates a pause between each beep sequence. For example, 1-2-3 indicates one beep, followed by a pause and two beeps, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes. Click here for AMI BIOS beep codes. 4-Beep Codes Beep Code Meaning 1-1-1-3 Faulty CPU/motherboard. Verify real mode. 1-1-2-1 Faulty CPU/motherboard. 1-1-2-3 Faulty motherboard or one of its components. 1-1-3-1 Faulty motherboard or one of its components. Initialize chipset registers with initial POST values. 1-1-3-2 Faulty motherboard or one of its components. 1-1-3-3 Faulty motherboard or one of its components. Initialize CPU registers. 1-1-3-2 1-1-3-3 1-1-3-4 Failure in the first 64K of memory. 1-1-4-1 Level 2 cache error. 1-1-4-3 I/O port error. 1-2-1-1 Power management error. 1-2-1-2 1-2-1-3 Faulty motherboard or one of its components. 1-2-2-1 Keyboard controller failure. 1-2-2-3 BIOS ROM error. 1-2-3-1 System timer error. 1-2-3-3 DMA error. 1-2-4-1 IRQ controller error. 1-3-1-1 DRAM refresh error. 1-3-1-3 A20 gate failure. 1-3-2-1 Faulty motherboard or one of its components. 1-3-3-1 Extended memory error. 1-3-3-3 1-3-4-1 1-3-4-3 Error in first 1MB of system memory. 1-4-1-3 1-4-2-4 CPU error. 1-4-3-1 2-1-4-1 BIOS ROM shadow error. 1-4-3-2 1-4-3-3 Level 2 cache error. 1-4-4-1 1-4-4-2 2-1-1-1 Faulty motherboard or one of its components. 2-1-1-3 2-1-2-1 IRQ failure. 2-1-2-3 BIOS ROM error. 2-1-2-4 2-1-3-2 I/O port failure. 2-1-3-1 2-1-3-3 Video system failure. 2-1-1-3 2-1-2-1 IRQ failure. 2-1-2-3 BIOS ROM error. 2-1-2-4 I/O port failure. 2-1-4-3 2-2-1-1 Video card failure. 2-2-1-3 2-2-2-1 2-2-2-3 Keyboard controller failure. 2-2-3-1 IRQ error. 2-2-4-1 Error in first 1MB of system memory. 2-3-1-1 2-3-3-3 Extended memory failure. 2-3-2-1 Faulty motherboard or one of its components. 2-3-2-3 2-3-3-1 Level 2 cache error. 2-3-4-1 2-3-4-3 Motherboard or video card failure. 2-3-4-1 2-3-4-3 2-4-1-1 Motherboard or video card failure. 2-4-1-3 Faulty motherboard or one of its components. 2-4-2-1 RTC error. 2-4-2-3 Keyboard controller error. 2-4-4-1 IRQ error. 3-1-1-1 3-1-1-3 3-1-2-1 3-1-2-3 I/O port error. 3-1-3-1 3-1-3-3 Faulty motherboard or one of its components. 3-1-4-1 3-2-1-1 3-2-1-2 Floppy drive or hard drive failure. 3-2-1-3 Faulty motherboard or one of its components. 3-2-2-1 Keyboard controller error. 3-2-2-3 3-2-3-1 3-2-4-1 Faulty motherboard or one of its components. 3-2-4-3 IRQ error. 3-3-1-1 RTC error. 3-3-1-3 Key lock error. 3-3-3-3 Faulty motherboard or one of its components. 3-3-3-3 3-3-4-1 3-3-4-3 3-4-1-1 3-4-1-3 3-4-2-1 3-4-2-3 3-4-3-1 3-4-4-1 3-4-4-4 Faulty motherboard or one of its components. 4-1-1-1 Floppy drive or hard drive failure. 4-2-1-1 4-2-1-3 4-2-2-1 IRQ failure. 4-2-2-3 4-2-3-1 4-2-3-3 4-2-4-1 Faulty motherboard or one of its components. 4-2-4-3 Keyboard controller error. 4-3-1-3 4-3-1-4 4-3-2-1 4-3-2-2 4-3-3-1 4-3-4-1 4-3-4-3 Faulty motherboard or one of its components. 4-3-3-2 4-3-3-4 IRQ failure. 4-3-3-3 4-3-4-2 Floppy drive or hard drive failure. 3-Beep Codes Beep Code Meaning 1-1-2 Faulty CPU/motherboard. 1-1-3 Faulty motherboard/CMOS read-write failure. 1-1-4 Faulty BIOS/BIOS ROM checksum error. 1-2-1 System timer not operational. There is a problem with the timer(s) that control functions on the motherboard. 1-2-2 1-2-3 Faulty motherboard/DMA failure. 1-3-1 Memory refresh failure. 1-3-2 1-3-3 1-3-4 Failure in the first 64K of memory. 1-4-1 Address line failure. 1-4-2 Parity RAM failure. 1-4-3 Timer failure. 1-4-4 NMI port failure. 2-_-_ Any combination of beeps after 2 indicates a failure in the first 64K of memory. 3-1-1 Master DMA failure. 3-1-2 Slave DMA failure. 3-1-3 3-1-4 Interrupt controller failure. 3-2-4 Keyboard controller failure. 3-3-1 3-3-2 CMOS error. 3-3-4 Video card failure. 3-4-1 Video card failure. 4-2-1 Timer failure. 4-2-2 CMOS shutdown failure. 4-2-3 Gate A20 failure. 4-2-4 Unexpected interrupt in protected mode. 4-3-1 RAM test failure. 4-3-3 Timer failure. 4-3-4 Time of day clock failure. 4-4-1 Serial port failure. 4-4-2 Parallel port failure. 4-4-3 Math coprocessor.
Oct 19, 2008 | Computers & Internet
Franke Saphira Espresso & Coffee Maker Logo
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Yves
Level 1 Expert
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
