My GE front loader washer is making a large banging noise and when it drains a large amount of what looks like sand or crushed gravel comes out???
  • 1 more comment
  • bhalderman Jun 23, 2009
    no - where is it?
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    some washers have a large cement block bolted into them as a counterweight to control the machine from banging the tub drum in high-speed spin; sounds like the block has broken; sometimes these fragments of cement dust get into the machine check the block counterweight inside the washer to confirm
  • Joe Povoas May 11, 2010
    did you clean the drain filter?
  • 111 Answers
But that cement block does not go inside of the drain pump.
Posted on Jun 24, 2009
How many yards in a ton?
As a rule of thumb, you can multiply the cubic yards by a factor of 1.4 to get tons. But remember, yards is a measure of volume where tons is a measure of weight. Thus, depending upon the material being calculated, true weight can vary greatly. Obviously a yard of wet sand will weigh far more than a yard of dry sand, as water is more dense and has more weight than the sand it displaces in the volume. Large crush stone may weigh far less than pea gravel for the same volume as there is less air gap around the gravel than there is around the large crush. If you need a true weight of a yard of some material, you would have to know its weight in a particular volume and then calculate from that value.
Nov 03, 2016 | Cars & Trucks
My GE spacemaker top loader will not drain, makes buzzing noise
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
May 29, 2010 | GE Spacemaker Washer and Dryer Electric...
Washer clunks and bangs hard when spinning. The
This is a simple repair. The main spring may have come loose from the top (need to check the top two springs ny removing top panel. The reaslon it bangs is from the dampeners being broke. Take off the bottom panel and look inside left and right at the bottom to see if the dampeners are broke. Fairly easy repair - takes some muscle. John<!-- from fixya rte -->
Mar 13, 2010 | GE WSXH208A Front Load Washer
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
MY SON LOADED A LARGE AMOUNT OF CLOTH INTO THE WASHER AND WHEN THE SPIN CYCLE CAME ON THE WASHER STARTED MAKING A HORRIBLE BANGING NOISE. it does not look like the springs are broken but the washer seems...
I'm suprised the unit was not able to spread a large load around to balance the drum. Maybe some item bunched up and made one side heavy. For a front loader, a proper load is just about all you can cram in there dry. You'll notice when the clothes get wet, they take less space, and when they are spun, there should be lots of room in the middle.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My ge front loader is making a banging noise while in spin cycle
When I was researching which washer to buy I read that this one is not the best choice to have on a second floor. Ours is on the main floor and can still be a little loud in the spin cycle. Have you balanced the machine properly? Otherwise, I think I read that people have had success putting a thick, dense rubber mat (like a stall mat for horses) under the washer to minimize the sound/wobbling. Good luck!
Patty
Jan 29, 2009 | GE WSXH208A Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
