Question about Coleman Rv Air Conditioner Control Box 8330b751
I have 2 air conditioners on my Hampton trailer. I can't get my furnance to kick on. I have a R V Comfort .ZC duel control thermostat with zone 1 ,liveing room, and -Zone 2 ,bedroom, zone 2 will say gas heat but furnace will not start. When I sketch it to zone 1 it says nothing. I just had the furnace in to service technition who put in a new ignitor . Hefired it up and it worked fine. INstalled it back in trailer but still can't get my furnace to fire up
    Habit-Forming:
    New Friend:
  • 117 Answers
I need to know what the furnace is doing .
Since you said furnace that's means force hot air and you have 2 Zone damper that's runs on 1 furnace ,correct?
If it's 1 furnace with 2 Zone is Zone 1 working
Posted on May 31, 2017
  • 13 Answers
SOURCE: I have a EVCON furnace DGAT070BDC. I replace the
You may have a dirty/rusty burner that is clogged or your gas valve
manifold pressure setting may be too low. Normal manifold pressure
is 3.5 inches water column on natural gas furnaces. ( 1 psig is equivalent to 28 inches water column). Pull and clean burner. Also
check and clean pilot assy. including flame sensor (if present).
Please let me know.
Posted on Oct 24, 2009
vetteman3002
  • 2299 Answers
SOURCE: i am installing a coleman
You have probably already answered this question. But as of now I can't see what any of the comments are other than the original question. What color are the wires from the AC and what color on the heat? Is this original wiring?
Posted on Oct 24, 2010
heatman101
  • 43501 Answers
SOURCE: Model FC24B3XN1H. Modulating Echelon 60k
The fan running constant and the unit not firing is usually an indication that the high limit reset has tripped.
And yes... these furnaces will run a cooler air... that is one way they get better efficiency...
Also the FC24... you have there is just the fan coil number...find the model number of the furnace...it will probably be on one of the walls just inside the top door...that will help me out more...to maybe find a solution for you.
heatman101
Posted on May 14, 2011
electrotech1
  • 1126 Answers
SOURCE: Coleman 7300 Travel Trailer Air Condintioner Model
It should not be moved when thre AC is on, becuase that will cause the thermostat to up around and could cause more problems.
Posted on Jul 25, 2011
heatman101
  • 43501 Answers
SOURCE: I have a winnebago that
The only way to track down a problem like this is to use an electrical meter and see where the power is and isn't....
once you find out where the power is stopping at then you can identify the faulty component and fix or replace it..
It sounds like it could be a thermostat or relay problem, being that the compressor or the blower are not running....
heatman101
Posted on Jul 28, 2011
My blower motor wont turn off in my furnance?
check the fan setting on your thermostat. On means always on, auto/int means only comes on during heating/cooling. if the thermostat is set to auto / int and the fan keeps running? you may have a bad fan relay switch. It may be integral on the primary control board of your unit.
Sep 04, 2014 | Heating & Cooling
Why does a CCC2 thermostat continually kick on and off even though the set temperature has been reached?
Double check your batteries in both the outside and inside units changing the outside ones FIRST before you change to reset the inside batteries, IF you have two separate units. If this doesn't help, it could be the control switch/relay for your interior unit. Please go to your browsers information line and type in DOMETIC CORPORATION.COM AND SEARCH FOR YOUR SPECIFIC THERMOSTAT by entering your CCC2 Comfort Control Center 2 information. They should have a help section at this website.
I hope this helps. Check to see if its still under warranty.
Jul 07, 2014 | DOMETIC CORPORATION Dometic CCC2 Comfort...
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
Thermostat shows error on unused zone
You will need to take the inside cover down on the front air conditioner. There is a control box mounted there, open the control box and you should see many dip switches on the face of the board. Make sure that Zone 1 and Zone 2 are selected (furnace as well if your furnace is fed through this thermostat). After making sure that the switches are set, turn off the thermostat and hold down the mode and zone buttons at the same time, turn the tstat back on. When EE appears on the face, release the buttons and see if everything works. If not, then I would say that you have a bad control unit in the air conditioner.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Jun 24, 2009 | Carrier 38CKC060 Air Conditioner
Thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Feb 18, 2009 | Carrier 38CKC060 Air Conditioner
Coleman Rv Air Conditioner Control Box 8330b751 Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
