Question about Amana ATB1832AR Top Freezer Refrigerator
How to fix refrig that is set on warmest setting and is still freezing item in refrig
Temp in refrig keeps getting colder and freezing items it is one the warmest setting. it is 18 years old .it makes a popping sound when you close the door
5 Suggested Answers
  • 531 Answers
SOURCE: Food in Chef's Pantry drawer freezes, even on warmest setting
check the cold control or the door is not closing proper
Posted on Apr 01, 2009
landsend
  • 1066 Answers
SOURCE: Freezing Items in refrig
number one is the lowest setting...try that
heatman101
  • 43501 Answers
SOURCE: the freezer items are frozen,the
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 03, 2011
heatman101
  • 43501 Answers
SOURCE: freezer items frozen,refrig not cold.I readjusted
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Which is colder 1 or 5?
My Avanti's temperature control is numbered 1 -5, and after 5 is MAX.
There is a separate control in the freezer section, but that is another matter.
As a matter of fact, in any refrigerator with a temp control, turning it towards the RIGHT will always result in COLDER.
If you open the door dozens of times an hour, you'd probably want to keep it on MAX.
If not, then MAX setting might begin to freeze some of the items you do not want frozen. If you are a normal user, try setting to 3.
Aug 16, 2014 | Avanti Refrigerators
Why is refrig so cold its freezing liquids
Good Morning Friend,
I understand that your Frigidaire refrigerator, model# FRS23KF7AB, is so cold that it is freezing liquids inside the refrigerator area. I also see that you have it set on the warmest setting. First, I suggest setting the controls to the factory setting. Secondly, reset your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, leave the setting on the factory setting, and give your refrigerator 24 hours to stabilize at the factory setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FRS23KF7AB Side by Side...
Items freezing in the refrigerator
Due to the ice on the vent ( damper ) , the damper is probably frozen open , so it will not close , causing the refrig section to keep on getting colder . Put your hand over the vent and feel the air being circulated . Use a hair dryer on the vent for a time and ocassionally feel the vent to see if the vent closes stopping the air flow .
Aug 01, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The temp setting is on 4 for both the freezer and refrig. Which way do we set the temp controls to warm up the temp? Is the lower setting warm or cold?
Good day,
The higher the number the colder the temp. 1 being the warmest.
It takes 12 to 24 hours to realize a new setting's effect. Go slow.
Apr 26, 2010 | Whirlpool Refrigerators
My refrig is freezing items on the refrig side.
likely a bad temperature control. also, some model GE's have a bad fresh food inlet cover, that fails to cutoff airflow from the freezer.
Feb 19, 2010 | Refrigerators
Freezing items in refridgerator
make sure the air passages are not blocked with food produts the other fix might be to un plug refrig and let it defrost for a day make sure you leave doors open
Dec 31, 2009 | GE GSS25LGM Side by Side Refrigerator
Lg side by side refridgerator ice maker
you can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Dec 10, 2009 | LG LSC27931S Side by Side Refrigerator
Refrigerator portion not getting real cold, freezer is ok.
I you have set the adjustment (if there is one and should be) on the fridge side to the colder setting, there may be an electrical issue with the control.
If there is not much in the fridge and you set it too cold, items will freeze.
Use a thermometer and make sure you have some items in there, test the temp.
You can just use a bunch of the ice pouches from a cooler to fill it up for this test, then see what it says the temp is, also check the manual you have or can get from the internet. It should tell you optimal temp.
More info on fridge is helpful, i.e. model number, mfgr date and so on.
Aug 31, 2009 | Whirlpool Refrigerators
Items in the back of the refrigerator freeze.
is this something that has just started happening? Most kenmore top freezers have a vent that allows cold air from the freezer into the refrig through a vent located on the back wall in the center of the refrig section. if packages are pushed up under this vent they can freeze.
If you have widespread freezing in the refrig setion then a temperature control could be the fault. thanks for using fixya. Peyton..
Feb 17, 2009 | Kenmore 72992 / 72994 / 72999 Top Freezer...
Amana ATB1832AR Top Freezer Refrigerator Logo
24 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
