Question about Acer Aspire One PC Notebook
Where is the Blue Function Key on laptop? - Acer Aspire One PC Notebook
My function key cannot control the brightness of my laptop
Are you pressing the 'Fn' key (usually blue lettering) to the left of the space bar before trying the function key for brightness?
Laptop function keys are either set to function as regular function keys or as system specific function keys, like volume and brightness control, when the system starts up. When you hold the Fn key, it makes that key do 'the other' function. These settings can be changed in the BIOS, of EFI settings. Though changing them is easy, you may want a semi-tech-savy friend to help the first time.
All the best to you,
KerryHos
Jan 27, 2014 | Samsung RV515 Laptop
Acer Aspire 7745G enable fn key
If you want to use blue print Fn key, just press and hold it with any other key that also has blue print in it. Fn key is locaded bottom left of the keyboard. Second one from the left to be exact.
If you want to use Function keys F1, F2 and so on. You should not press Fn key which will change Function keys to function differently.
Feb 16, 2013 | Acer Aspire 7745G-9823 Notebook
Laptop screen is black
There are a couple of reasons that a laptop screen could blank our. The first is that many laptops have the ability to output video to an external monitor or projector, such as for video presentations. In order to save battery life, there is a function key combination that can be used to blank the laptop screen. Most laptops have these "functions" on the F1-F12 keys in blue and there is an "fn" key that must be used with them to activate the function. Look for a key that has a blue "square" with vertical lines on either side of it. This is the Monitor function key. Press and hole the "fn" key, then press the Monitor function key. See if the screen returns. A corrupted video driver could also be the problem. Do you have any display when booting up? If so, try using the F8 key to get to SAFE Mode. If you have a display there, check and see if there are any problems with the video driver, or just reload the driver. The third possibility is the the LCD's backlighting source may have failed. IF this is the case, you probably have an older laptop and replacement is usually cheaper and more cost effective than repair.
Jan 09, 2012 | Acer Computers & Internet
WHY NOT WORKING FUNCTION KEY
when you hold down function key you need to press one of the blue colored icons
some function key's need drivers installed for them to work
is this a new laptop?
try reinstalling the drivers your laptop came with, from its recovery CD/DVD
Mar 29, 2011 | Computers & Internet
Please advise if there is any step/key that could release the use of key with blue note function. i.e. on "M" key, the blue note is "0", if I could not release its blue note...
There is function key in your laptop which is blue in print and written Fn which means there are some keys like u say 0 written on M it is zero in numbers which work only when u have switched on your numlock.To get back to M switch-off numlock.
Jan 05, 2011 | Samsung Computers & Internet
My laptop keyboard has optional "blue" upper and lower case letters and punctuation. how do i turn these on or off. they seem to work independently. i must be turning them on or off without knowing it.
Those keys with the Blue function keys only works when you press the Function Key together with it those keys in blue. . .
Check every single keyboard key. you should find "F" in blue. . .
Oct 27, 2009 | HP D8597A Keyboard
FUNCTION KEYS ON DELL INSPIRON 8000 DON'T WORK AFTER INSTALLING W
There is no driver required to use the function keys. You just need to use the function (fn) like a shift key. Hold the function (fn) key and then press the according function key.
Mar 20, 2009 | Dell Inspiron 8000 Notebook
Blue Button under right and left button on IBM Thinkpad T20
The blue buttons on the Thinkpad are designed to be used with the blue FN key ( Lower left ). Press and hold the FN key, then press the applicable blue function key.. I.E. Brightness, Volume.. etc.
Nov 19, 2008 | IBM ThinkPad T20 2647 Notebook
Numbers locked in on Dell Laptop
Look for the Num Lock key written in blue, press the FN key and press it. It will turn off the number keypad.
Jun 20, 2008 | Dell Latitude D600 Notebook
Keyboard probs advent 9115 laptop
Sounds like your num lock has been toggled on by mistake. Look for a key that says NmLK. It will be in the same color blue. That key may also be the scroll lock key(ScrLk) that should solve your problem.
Thanks
Todd
www.LaptopGuy.com
Apr 23, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
52 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
