Question about Whirlpool Washing Machines
Whirlpool duet washing machine duet repair F8 E1
Model WFW70HE
  • 66 Answers
SOURCE: Whirlpool duet washing machine
noisy may be the tub is hiting some thing. you can open the top of the washer and ck. it is very simple. sud are you using the he soap.
Posted on Feb 16, 2008
SOURCE: unlock control lock in washing machine, whirlpool, duet
Hold control lock for 3 sec. It will make a sound and the door will unlock.
Posted on Mar 21, 2009
  • 289 Answers
SOURCE: f14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
Posted on Jan 15, 2010
  • 901 Answers
SOURCE: I am looking for the service manual for the
Pl search through google search
Posted on Mar 31, 2010
  • 17 Answers
SOURCE: What is the cu. ft of my Whirlpool duet washing ma...
3.7 CUFT
Posted on Aug 11, 2010
Whirlpool washer F3 E1
F3E1 Error - Pressure switch/ sensor fault.
  • Your washer cannot detect the water level. Check the pressure sensing hose for kinks or blockage or the pressure sensor itself.
  • I won't leave you without a clue. Follow the link below and it will explain more than I can write here.
  • http://applianceassistant.com/Washer-Repair/Duet/Duet-Washer-Error-Codes
  • Jan 02, 2017 | Whirlpool Washing Machines
    Duet. What does F8E1 code indicate needs to be done to restore operation?
    Check out the Link and the info below.
    Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
    F8 E1 or LO FL Code in display:
    No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
    If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
    Check the water supply:
    Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
    NOTE: Both Hot and Cold water must be supplied to the washer.
    Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
    If a "flood saver" device is being considered:
    • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
    • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
    Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
    Jan 19, 2016 | Whirlpool Washing Machines
    I have a whirlpool duet model wfw70hebw. The washer stopped and I can't unlock the door. Have error code E1 F9
    Try unplugging for 30 seconds and plug back in. See if you are able to reset the controls after that.
    Jan 24, 2015 | Whirlpool Washing Machines
    Whirlpool Duet washer error E3/F8
    RTM. Read the manual. If you misplaced the manual, get on by going to Google, put in your make, model and the word manual and you should get the .pdf file of your manual, download it and read it.
    Oct 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    How do I fix a Duet Front Loader displaying a F8 E1 error Code?
    Without model Number going on experience they change based on model the error codes F8E1 is a long fill error code if you have flood safe water supply hoses install regular washing machine hoses most common issue pull machine out remove back panel inspect black hose that runs from pressure switch to plastic tub the clip that holds it in place usually comes loose allowing it to rub against the rotor of the motor causing a hole to develop which will give a F8E1 code
    Aug 30, 2014 | Whirlpool Washing Machines
    Washing machine E1
    You have not included the make and model of your washer so that makes it pretty hard to answer for sure. A google search shows that several makes have an error code of E1 and it refers to a slow drain. Attached youtube video link is for a whirlpool washing machine and might help. If not repost with the make and model of your washer.
    Washer Repair Drain Pump Error F9E1 Maytag 2000 Series Whirlpool Duet...
    Aug 16, 2014 | Washing Machines
    Model number wfw9250ww error code e1 and f6
    How to fix a error code of E2F3 on a whirlpool duet model # wfw9250ww00
    May 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    13 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
