Question about Amana Refrigerators
Why does my 18 yr old amana top freezer refrig, freezes thing in refrig. when on warmest setting
It seems to be getting colder and colder, duel controls freezer set on 3 refrig set on 1 the warmest. it runs long and popping sounds when you close door
landsend
  • 1066 Answers
SOURCE: Freezing Items in refrig
number one is the lowest setting...try that
Posted on Apr 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: ed22pwxxn00 setting on 3 top shelf items freeze.
Adjust the freezer damper to a higher number to reduce cold air flow to the fridge section. This will eliminate freezing in the fresh food section.
Posted on Aug 29, 2009
SOURCE: cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Posted on Sep 12, 2009
  • 66 Answers
SOURCE: @15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
Posted on May 17, 2010
heatman101
  • 43501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 28, 2010
My refrigerator is too cold. It is on the warmest setting on both the freezer and refrig yet the lower draws freeze. Got any ideas? And yes the compressor is not running all of the time.
by setting the freezer control to the warmest setting you allow the maximun amount of air into the refrigerator. set the freezer control to the center location.
Mar 28, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker not working. refrigerator is freezing everything. seems to run all the time.Help!!!!!! It is an Amana about 10 yrs old.
if you have the settings correct then the cold control(ref setting) is bad. but some older models use a baffling system which confuse some people. the freezer settind turned to the lowest setting make you fridge colder. when you put the freezer on the highest setting it allows less airflow. which in turn keeps ref warmer.
Aug 01, 2010 | Amana ATB1832AR Top Freezer Refrigerator
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
Apr 03, 2010 | Amana ABB1927DE Bottom Freezer...
heatman101
Mar 30, 2010 | GE GTS22KBP Top Freezer Refrigerator
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Why would my refrigator be freezing my food set at the lowest setting it can be set on
If it has a damper at the top left wall , the damper is bad or the refrig control (possibly circuit board) is bad .The damper closes to reduce the air flow to the refrig yet the freezer section can still get colder if needed . The refrig control or circuit board for the fridge control , works the damper . If you feel air coming thru the damper , it is not closing , causing your food to freeze .
Jul 18, 2009 | Amana Refrigerators
Thermostat problem
is the refrigerator section is freezing up
Apr 04, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
12 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
