Question about Sharp EL-2630P Calculator
UNJAM PAPER IN CALCULATOR
UNDER THE ROLLER, PAPER IS JAMMED, HOW TO GET IT PART TO CLEAN
2 Suggested Answers
  • 168 Answers
SOURCE: Paper/tape jam
Get a pair of scissor and cut through the tape. IF it is rapped up too tight where you can't get a pair of scissor through it, then get an exacto knife or razor blade to cut the paper. Just remember not to press too hard so you don't cut through the rubber roller beneath it.
After cutting the paper, then press the paper advance and start taking the pieces of paper out.
Good luck.
If you still have problems, feel free to repost again.
Have a good day.
Mac =)
Posted on Mar 26, 2008
Paper tray jam
I would first go to the manufactures web site and ask for support. In the mean time, I would open up the paper tray and inspect where the paper feeds into the rollers. If there is another access point, where the paper comes out, inspect that area as well looking for paper or fragments. Sometimes if you can turn the print rollers by hand a paper jam will reveal itself
Jan 20, 2015 | Dell 3765dnf Colour Multi-function Laser...
Misfeed detected. Remove paper indicated by 0
misfeed is different then a jam. jam is the paper hit something miss feed the paper rollers can not pick up the paper. clean the rollers or replace them and or there associated clutches
Feb 21, 2014 | Konica Minolta Bizhub C451...
. Jammed paper message stops printing but no
WHen this happens is because there is some residue of a piece of paper inside the rollers.
Make sure to check all the rollers by opening the doors that give access to the unjammed papers.
Try powering off and on the printer to see if it fixes the jam message.
Buy check the rollers from all the opening doors available.
You might also use compressed air to clean it.
God Bless You!
Feb 05, 2011 | Canon Office Equipment & Supplies
As soon as you press print it acts like it's going to work then the wheel makes a sound and it stops, like the wheel is locked up or something. It says printer error. Remove back access and unjam the...
That usually means that the paper feed rollers are not pushing the paper into the printer. Take a paper towel and some isopropyl alcohol and clean the rubber rollers were the paper is set and feed into the machine.
Aug 25, 2010 | Office Equipment & Supplies
My dcp 150c printer has been jammed for weeks, i have done everything it said in the manual but it won't unjam
This Brother printer could have a piece of paper stuck in it. When a paper jams, assemble the jammed page pieces to make sure all the pieces came out.
A jammed paper can also knock loose the paper detect arm that senses a paper in the machine. This detect arm is usually near the platen (The roller the print head prints against) to detect paper in the machine. If this arm is stuck, it could be sensing paper when there is none.
Rubber paper rollers should all be cleaned with rubbing alcohol or a mild soap solution (I use Windex) to prevent feed jamming.
Mar 28, 2010 | Office Equipment & Supplies
Printer is ripping paper, and getting jammed
Most likely you have something on the roller or jamming it. I have disassembled printers to find paper, paper clips, and other things helping to jam the paper roller. Try to clear the obstruction by checking around the roller anyway you can. As I said, sometimes you have to take the printer apart to get to the problem. Sometimes it's a bad gear, so it can get a bit tricky. It's your call- you might try to unjam it, and if that fails, replace it- they're pretty reasonable these days, anyway. Good luck!
Mar 11, 2010 | Lexmark X3650 Printer
Hp 4100 paper is jammed between rollers the back panel should come off? and then how do I get fuser out to unjam paper
Hi Jacque,
I gather the paper has got into the fuser and cannot get into the output bin. Few things...
1. Clean output rollers. Are rollers moving?
2. Check gears on the fuser unit. Any broken or worn gears?
3. Check default paper size setting in printer, paper size setting on tray, paper size setting in printer driver and document page.
4. Leave the back door open. Does the printer still jams? If it does, see it could be paper pick up problem. Use different trays or the manual feed. Also the fuser unit could be the problem.
5. All else fails, replace the output assembly.
Rgds
S88
Dec 18, 2008 | HP LaserJet 4100 Printer
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Paper Jam
locate at the back portion of your printer there is small rectangular like a door pull up and then get those paper that causes paper jam slowly see to it that there is no paper left....and start printing again if it does not worked then try to clean your paper rollers...
Oct 22, 2007 | HP Photosmart C6180 All-In-One InkJet...
Sharp EL-2630P Calculator Logo
122 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
