Question about Husqvarna Garden
My Husqvarna blower, model 130BT, bogs down when it is revved up. It runs better when the air filter is removed although certainly not as well as should be expected. I took out the filter, cleaned and replaced it but the blower still bogs down with the air filter installed. Help!
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 23, 2009
  • Jim Parker
    Jim Parker Jun 24, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
130BT Blower can't pull start cord.
Can be a couple issues. The obvious is seized. The other is a broken jammed connecting rod. I would put some oil down the plug hole and let it sit overnight. Then after a day or so...try again with the wratchet. In both directions, forward then backward just to try and free it.
Nov 22, 2015 | Husqvarna 130bt 130 Bt Gas Powered...
Picture of timing marks on briggs 6.5
Maintenance diagram od Husqvarna 130BT timing gap settings.
Apr 05, 2013 | Husqvarna 295cc Back Pack Blower HVH 130BT
HUSQVARNA 130BT GAS BLOWER STARTS FINE, BUT LOSES POWER WHEN I TRY TO USE????
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
Mar 02, 2013 | Husqvarna 130bt 130 Bt Gas Powered...
How do you get to the throttle jets huskvarna 130BT blower
The 130 has a rotary style carb, so the only adjustment is down through the top of the throttle spindle, you will need a very small flat blade screw driver, the screw down here will lift or raise the needle in the carb, there may well be a plastic plug to remove before you can get deep enough to adjust it.
Dec 27, 2012 | Husqvarna 295cc Back Pack Blower HVH 130BT
Huskvarana blower 130BT starts but will not stay running
Fueling issue, check primer bulb and fuel line for air leaks, and possible clean and service card.
Dec 27, 2012 | Husqvarna Garden
New; ran 4-5 hrs; then quit. now no spark.
Check the spark! Could be the ignition shuts down when the engine runs too hot. You could use a little more oil mix.
Nov 09, 2012 | Husqvarna 295cc Back Pack Blower HVH 130BT
I've had my 130bt blower for about a year now and in the past week it hasn't been running good at all. Never had a problem until now. when i squeeze the throttle it seems to bog down and die, if i...
It's probably not the Coil; that's the good news. The bad news is it's probably the small screen in the carburetor. So you will need to take the carb. apart again. I'm sending you a Link to my Tip(s) on this problem. The first one is fuel line check, and then you can go to my carb. clean Tip from there.
Good Luck!
Jim
Aug 20, 2011 | Husqvarna 295cc Back Pack Blower HVH 130BT
My 130bt blower stops reving after several minuets. Will start but not rev after running fine for 5-7 minuets?
Hi and welcome to FixYa. I am Kelly. The next time it does this... loosen the gas cap a lot momentarily for about 10 seconds then tghten it and attempt a restart. If if starts right away again the gas cap is bad. It is supposed to breathe via a rubber seal in the cap. There are 5 parts in the cap. If it can not breathe the gas tank goes into a vacuum as fuel drains and you will experience fuel starvation.
Also check inside the fuel tank for debris.
See this link http://www.jackssmallengines.com/help.cfm#Home
Click on
Husqvarna Power Equipment
Blowers
130BT (I used the 2001 - 2007) There is also a 2008-2010 choice
and then click on Fuel tank a.s.s.y
I suspect the problem is either going to the the fuel cap or the fuel filter.
Thanks for choosing FixYa,
Kelly
Nov 10, 2010 | Husqvarna 295cc Back Pack Blower HVH 130BT
Garden Logo
1,162 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
