Question about Kenmore Refrigerators
Model 59658642891 freezer section is not freezing properly
Freezer compartment is freezing at the bottom but not at the top
SOURCE: Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Posted on Nov 05, 2008
SOURCE: the fridge section is working
doubt if a manual is available at all
tresilla
Posted on Nov 08, 2008
  • 88 Answers
SOURCE: FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Posted on Dec 06, 2008
SOURCE: Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Posted on Mar 23, 2009
SOURCE: fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Posted on Aug 13, 2009
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
The top of the freezer compartment does not freeze ice, but the bottom does. The top of the refrigerator compartment is not cold, but the bottom drawers are freezing.
It sounds like the fan in the freezer is not working , letting the cold air sink , and going into the refrig section from the bottom . Replaceing just the main control board may get the fan going again , however , replaceing both ( possible shorted fan motor will cause the new board to malfunction again ) would be the better suggestion .
Mar 04, 2010 | GE GSS22KGPBB / GSS22KGPWW / GSS22KGPCC...
Jenn-Air Jrsd 249t top is warm... bottom freezing
Uncertain as to whether this is a "freezer at top or bottom" model? Make certain that temperature control settings are approximately at the one-half way for both the freezer and fresh food compartments. If freezer at bottom, you may have a defrost component issue (defrost thermostat or heater). If so, contact an appliance service company.
Feb 10, 2010 | Refrigerators
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge not working properly on kenmore bottom freezer model 596.7
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Pooling Water
Hi!!!Your drain line is frozen and plugged.Try to remove the cover of the evaporator and you should see a small hole on the base of the evaporator thats yout drain line hole. Blow it away and your problem is gone..Good luckk..Plugged drain line..
Dec 23, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Oct 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
