Question about Polycom >>> SOUNDSTATION PREMIER EX /AVAYA CO-BRANDED (230501900001)
Can dial out but polycom won't ring on incoming.
I am having the EXACT same problem. i don't see any solutions posted here; just wondering if you got an answer elsewhere you could share.
Thanks~
4 Suggested Answers
JackHeath
  • 1049 Answers
SOURCE: Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
Posted on Oct 01, 2009
  • 6 Answers
SOURCE: I have a polycom viewstation FX and appear to have
How many lines (circuits) do you have going to your system? Is it possible they are out of order? Give me your ISDN numbers and I'll try to connect to you. Where are you located? My e-mail address is sducz5@aol.com
Posted on Jan 27, 2011
  • 146 Answers
SOURCE: Can anyone tell me how
No it can't. One call at least must be dialed out to. Try using a conference bridge service if you want to have multiple parties call in to you. Then you and all guests only need to call bridge number which is usually toll free.
Posted on Mar 01, 2011
Polycom soundstation 2 does not have a dial tone
That Polycom runs off of Analog dial tone.
Either a dedicated line or in most cases from an ATA off the phone system.
You should be calling your vendor/tech in that handles the phone system to check programming, cabel, jack and the Polycom itself too.
Dec 11, 2012 | Polycom Soundstation 2 Full Duplex...
Hi, I have Ploycom QDX6000 and facing two problems. Please let me know if you can help me to fix the same 1- I can not pick the call is someon calls but i can dial out successfuly 2- Fan-end camera...
1) try setting unit to auto answer and it will automatically pick up incoming call
2) far end will only control a Polycom camera and it will not work through a bridged call - it must be point to point
hope this helps you
good luck!!
Mar 31, 2011 | Polycom QDX 6000 (720030831001) Video...
We moved our Polycom Soundstation 2 from one office to another. It was disassembled and reassembled by who knows who. It is using an analog port from an NEC DSX 80. It recognizes an incoming call, but,...
sounds like the 'brick' went bad
this is the power supply try replacing it
also and possibly more important did you reprogram phone and phone number when you moved it??
make sure you reset all settings and start new
Mar 17, 2011 | Polycom SoundStation
Can anyone tell me how to place a conference call using the Polycom SoundStation2 when both calls are incoming? I am able to place an incoming call on hold and dial another number and conference them...
Feb 21, 2011 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
I have a polycom viewstation FX and appear to have problems regarding the ISDN. We seem to be able to connect outgoing calls ok (however it does take a long time). But incoming calls do not connect, just...
Dec 08, 2010 | Polycom ViewStation ISDN (pcy220011323001)...
No dial tone,still ringing with incoming calls,display reading power failure and out of range
Sorry, this is not a solution, but I have the exact same problem! Did you ever figure it out??
Sep 10, 2010 | Vtech Lands Phones
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Polycom soundstation Ex - no dial tone
Someone in our office recently damaged the RJ-45 cable for our Polycom Soundstation. Because the jack was damaged I could not determine the order of the cables. After a call to polycom, we found the pinout information we needed - so I thought I would share, in case anyone else finds themselves in a similar situation:
With the RJ-45 prong pointing down the wires, from left to right are:
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Then Crimp and test. I got this information directly from Polycom for use with the Polycom Soundstation. This information was not easy to get. They originally told me they could not provide the information and I would have to buy a power adapter. This is not true, just trim the cable and follow the above instructions.
Sep 14, 2007 | Polycom PCY220016000001 SoundStation2...
Polycom >>> SOUNDSTATION PREMIER EX /AVAYA CO-BRANDED (230501900001) Logo
396 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
