Question about Toshiba DKT3020-SD Display Telephone
How to re-program extension numbers & retrieve voice mails
We re-organized the office and switching rooms. How do we change the extension number in a room. One person retired and we do not know the password on his phone so we can not retrieve the voice mail. We also need to change the announcement on our voice mail.
  • 4102 Answers
SOURCE: Changing Voice Mail Password from the TOSHIBA DKT2010-SD set
you will need to download the manuall you should be able to get it off this sight hope this is some help
Posted on Oct 30, 2007
  • 45 Answers
SOURCE: voice mail
Is voicemail answering at all?
If so dial the ext to access voicemail.
Dial * 990# or *991#
enter password #
Follow prompts.
Tony
Posted on Apr 03, 2009
  • 38 Answers
SOURCE: DKT2020-SD Msg Light Blinking for no reason
#409 to cancel receive message...may need to key in few time to cancel few message
#64+sent messane extn - to cancel sent message
Posted on May 09, 2009
karenw959
  • 4 Answers
SOURCE: Password
Type in on telephone keypad:
5555#*
999#
999997#
Select Option 8
Select Option 4
Type in extension number you’d like to change followed by #
Select Option 5
Go to telephone you’ve just changed and type in 5555
Enter extension number followed by 997#
Select Option 3
Select Option 2
Select Option 3
Enter new security code followed by #
Confirm new security code followed by #
Hope this helps, Karen
Posted on Sep 08, 2009
  • 66 Answers
SOURCE: how to reset the voice mail password for toshiba
Log into mail box 999 and use sec code 999997 or just 997 and press 8 for admin functions. you might want to read the admin Guide
Posted on Feb 11, 2010
Canceling call forwarding from one extention to another
On the extension that is forwarding use Feature #4 to cancel the call forwarding unless it is programmed under the capabilities section in programming. This will require someone with programming ability to make the forwarding change back to the voice mail access number.
May 01, 2013 | NorStar M7310 Corded Phone
I can't log into my Nortel vm account
Change the administrator password by pressing Feature 985 dial 9 even though it is not listed as an option. The display will show Pswd: dial 73738767793. The display will show Reset pswd? Press YES. Now you can log into the voice mail system administrator using Feature 983 and the password 1020000 if you have 3 digit extension numbers. Add or delete the 0 between the 1 & 2 depending if you have 2 digit or 4 digit extension numbers.
Sep 17, 2012 | Nortel Networks T7316E Telephone Platinum...
Change the extension name? For examlple change from 109 to 122
Is that a name or a number?
Extension numbering and name are in system programming and that's a function of whatever system you have, not the phone. Generally, it's in system program 003 and 004 for number and name respectively.
In number change, most Pana systems require you to change one extension to a number not being used. In a TA-x24, the numbers are still assigned in software to 124, so you would change 109 to something out of the universe like 133, then change 122 to 109 and 133 to 122 :-)
If you have voice mail you may have to manually assign it via the owner's mailbox 999 or from the maintenance console or hyperterm.
Carl
Oct 21, 2010 | Panasonic KX-T7730 Corded Phone
We need to set up a voice mail for an extension that has not been used in years. When I press intercom 777 and enter extension it tells me to enter password which no one in the office knows anymore. When...
The default password on partner voicemails is 1234. The reason for the call returning to the extension that transferred the call to the new extension is probably because the cover vms isn't set up for the new extension.
To check the vms cover for that extension, at either extension 10 or 11 press feature 00 and press the left hand intercom button twice. The display will say system programming.
Enter #310, the display will sayAutomatic VMS Cover Extension:
enter in the extension number of the new extension.
The screen will say either "1 assigned" or "2 not assigned"
enter in 1 (assigned)
press feature 00 when finished.
Sep 30, 2010 | Avaya Corded Phone avaparp18d
I have 1 extension that will not go to voice mail. I have tried the *713 and a 2 digit number between 00 and 99 and it still just rings endlessly. When I make an inner office call to this ext... it picks...
What happens when you TRANSFER an outside call to that extension? If that works, you have Intercept issues which is handled with programming. If it still does not transfer, you have CF issues, started by a *710x command for both internal and outside calls.
Carl
Aug 11, 2010 | Panasonic KX-T7633 Corded Phone
HOW TO RETRIEVE VOICE MESSAGES? DOES THE PHONE DISPLAY YOU HAVE A VOICE MESSAGE? IF NOT, THEN WHAT IS THE FEATURE CODE TO ENTER AND OBTAIN MSGS.
The display on a Nortel set will say "message for you" if there's a message in your mailbox. To access your voicemail you can press your open voicemail key if its programmed or press feature 981.If you wish to retrieve your messages remotely, call your office, when the autoattendant answers the call press ** followed by your extension number, your password then # (ex. **2231234#).
Jul 09, 2010 | NorStar M7208 Corded Phone
How do I re-progam voicemailor shut voice mail off
Voice mail is activated by putting extensions in Group 7. Since you can have several different voice mails, it's difficult to tell you exactly. 777 gets you in, and 99 or 999 should be the access, but not always.
If you are unfamiliar with programming, try going to the room where the system is located and read the cards and version numbers and post back. Your VM could be a PC card, a standard Partner card, or (unlikely) a seperate box mounted on the wall.
Carl
Nov 17, 2009 | Lucent PARTNER18 Corded Phone
Change Extensions on NEC IDK Phone?
It is easier to move the wires but if you know how to go into programming than change the extension numbers on the ports in mb 4-10
Apr 28, 2009 | NEC DTU 8D-2 Corded Phone
Toshiba DKT3020-SD Display Telephone Logo
26 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
