Question about KitchenAid Refrigerators
Won't enter diagnostics mode - KitchenAid Refrigerators
2 Suggested Answers
SOURCE: Xerox DocuColor 1632 /2240 Enter the Diagnostics Mode
fuji xrox 2240 error code 102-372
Posted on Feb 15, 2010
Enter diagnostic mode in mod 11028002010 toploader he washer
Washer topload diagnostic mode. - YouTube
? 5:00
https://www.youtube.com/watch?v=jipYd_qeCqs
Jun 17, 2014 - Uploaded by Al Fixit
How to put kenmore washer into diagnostic mode. ... How to Use HE Top Load Washing Machine: Informational Tips From Sears Home ...
Entering Diagnostic Mode in a Whirlpool Vertical Modular ...
? 1:02
https://www.youtube.com/watch?v=7kWrIPaWLUM
May 8, 2012 - Uploaded by SamuraiRepairman
Shows how to enter diagnostic mode in the Whirlpool VMwasher. Created on May ... The first was no error codes. the second said that we had an unbalanced load. I'm not sure ... I had a repair person out to my house he reset the computer panel and it worked. Now its ... washer. Raise the top panel to get it.
Diagnostic mode for Kenmore Elite Oasis HE Top Load ...
Dec 12, 2015 | Washing Machines
What does code po745 mean on a 2004 lincoln ls v8
Here are some code definitions: I am also including a link to a forum discussion of the problem. The forums can be very helpful.
P0745 Pressure Control Solenoid Malfunction
P0745 OBD II Trouble Code
2000 LS transmission P0745
Jan 16, 2015 | Lincoln Cars & Trucks
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
Ice maker not dropping ice, the switch is on, and the ice has been in the tray for quite some time now
POWER ON DIAGNOSTICS TEST MODE When the ice maker is first connected to power and the thermistor temperature is 50°F or more, the control will initiate a “Power On” test before entering the freeze cycle. The test will consist of the following sequence:
1)Turn on the motor until it reaches home position
2)Turn on the water valve for 1/2 second
3)Turn on the heater for 1/2 second
4)Verify that the feeler arm was in the “in” and then the “out” position.
5)Verify that the motor was not in the home position and then in the home position.
6)Verify that the motor does not remain on after being turned off.
7)Proceed to the freeze cycle. SERVICE DIAGNOSTICS TEST MODE During the first 15 seconds that power is first applied to the ice maker, the Service Diagnostics Test mode may be entered. The Service Mode is entered by pushing the feeler arm in and out three times within 15 seconds. (only three times). There will be only one fill cycle (5.1 second) in the service diagnostics mode without the waiting period for the mold to “pre-chill”. If the ice maker has already started a harvest cycle and the arm is moving, it may be impossible to start the service mode. (since the NORMAL cycle is already started). While in the “Power On Diagnostics” test mode, the “Service Diagnostic” test mode can be initiated and will override the “Power On Diagnostics” test mode. This ice maker has no replacement parts available and is not intended to be repaired.
Jan 26, 2010 | Refrigerators
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
My Fisher paykel dryer does not heat
Thermostat Cutout – Manual Reset (Electrical)
Type SPST 30 Amps/240 Volts AC
Trip Temperature 212°F (100°C)
Diagnostic Mode
button.
Last Fault
Conductivity Contact Impedance Check
To enter the conductivity contact impedance check, enter the diagnostic mode
as described above, then press the Auto Dry up button five times. In this
mode, touching damp clothes or fingers across the conductivity contacts will
cause the LED display to change. If the contacts, or the harness to them,
have gone open circuit, no change will occur in the LED display. This is a
useful method of checking the integrity of the sensor circuits.
To exit the diagnostic mode, press any cycle button.
Entering the Data Download Mode
button. This enters the diagnostic mode.
(c) Press the Regular button.
Encoded data is transmitted serially out the red Auto LED, and is be captured
by an optical download pen attached to a PC where “Smart Tool” software
interprets the data to aid servicing.
To exit, press the Regular button.
Entering the Showroom Mode
(b) Press and hold the Air Dry button, then press the Power button.
The LEDs will flash in a random sequence.
To exit, turn off the power supply to the dryer at the wall.
Tell me what sort of faults codes you can come up with and I will tell you what it means but in the meantime reset the limit and clean out the lint problem, open the stopped up vent. That dryer has to breath or that safety will kick out again. I have the manual
Sep 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Xerox XC1875 U4 Error on Startup
Give this a try. it may clear you code. Use program 14
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
**To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics.
May 04, 2009 | Xerox Office Equipment & Supplies
Internal diagnostic mode
To enter Test Selection mode from Customer mode and display the Test Selection screen:
  1. Select Information -> Troubleshooting -> Service Tools from the Control Panel.
  2. Scroll down to Enter Diagnostics and press the OK button.
When the system transitions from Customer mode into Test Selection mode, the initial Control Panel display is the Test Selection screen as follows
Dec 31, 2007 | Xerox Phaser 8500/DN Printer
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
