Question about Canon MX882 All-In-One InkJet Printer
Why is my mx882 scanning slowly - Canon MX882 All-In-One InkJet Printer
Canon MX882 printer won't copy from the glass. Why?
Is the scanner light coming on? Check that first.
Oct 24, 2016 | Canon Office Equipment & Supplies
How do I get rid of the lines when I make copies. It dose not happen if I print a scan
If you are using the ADF ( automatic document feed ) for your copies, raise the scanner cover and clean the strip window to the left of the main platen. If you are using the platen for copies and getting lines where scans are clean - you have a physical issue and it should be checked out by a technician.
Apr 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
My MX882 keeps feeding from back tray. How do I get it to print from front tray ?
Press the MENU button, select TOOLS or SETUP, select DEVICE SETTINGS, then plain paper feed settings and alter the settings to suit. This can also be performed from the computer from the printers and faxes folder (or devices in Win8). Open the printer window, click "Printer" then printer preferences and select paper source.
Feb 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
How can I scan a photo to a program on my computer
You can scan using the software that came with the printer. You can download them at Canon Support Drivers PIXMA MX882
Jul 16, 2014 | Canon MX882 All-In-One InkJet Printer
Can it scan film negatives?
You cannot scan negatives or slides with this all in one printer.
You need a film scanner.
May 07, 2013 | Canon PIXMA MX882 Wireless All-in-One...
I have a Canon Pixma MX882? How do I scan to my computer?
In this case Try to Do a Wia scan i will tell u how..........
Windows Vista: Go to Start/All Programmes/Windows Photo Gallery...........
There you will see an option saying File click on that and now on the drop down click on Import from Scanner or Camera.........Select ur scanner from that list and click on Import.............
If it doesnt scan and does the same thing it insists that there should be a Problem with the scanner.........
If that works..........
Software Problem.............
Uninstall and Reinstall the software................
Good Luck..................
Sep 26, 2011 | Office Equipment & Supplies
Where is the model serial number on the Canon MX882
Issue: Where is the serial number located?
Solution: Locate the serial number MX882
Locate the Serial Number The serial number of the MX882 is located inside the printer, as shown below.
  1. With the printer powered on, open the Paper Output Tray (A).
    The above illustration shows a PIXMA MX870.
  2. Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
  3. Wait until the print head carriage moves to the ink tank replacement position.
  4. To the right of the print head carriage, inside the printer, is a white sticker that is attached to a metal plate. The serial number is located on the white sticker. Please see the illustration below.
    The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
May 09, 2011 | Canon Office Equipment & Supplies
Canon MX882 All-In-One InkJet Printer Logo
27 people viewed this question
old marine
old marine
