Question about Canon Office Equipment & Supplies
Paper not moving thru machine . for about a month prior there was a straining noise when ever a copy was printing, now there is no noise and no copies
    Problem Solver:
  • 3 Answers
Sounds like a paper feed clutch went out
Posted on Jun 23, 2009
Canon 4570dn squeals loudly when drawing from MP Tray
Hi
It sound like friction noises. it could be because of the rollers and lubrictaion on gears that got hard creating the noise and also produce strain on the feed motor . I would sugest a good service on all mechanical parts.
Dec 05, 2013 | Canon Office Equipment & Supplies
My MP 830 printer will no longer feed copies from the automatic document feeder. The machine makes noise like gears slipping and the paper goes one fourth of the way and then stops before it can go down. ...
Check the feed roller on that paper tray. if the roller is made of rubber clean it with the eraser on a pencil making sure to clear away any extra dust. the Eraser will re-surface the roller to grip better.
Also check inside not just for blockages but sensors that may be stuck, such sensors may look like black armatures that move easily and light sensors that easily clog with dust.
Remove the print cartridge and dust out the entire paper path.
May 02, 2008 | Office Equipment & Supplies
The copier makes it half way thru the copy the stops with a paper jamb usually on the print table. I keep having paper jamb issues also have finger prints on copies which started after I removed the toner...
The jamming with the copy half way thru is almost always a broken fuser drive gear. The unit that gets hot as the paper exits the machine. Check the back side of this unit. You will see a gear, or part of a gear that is about 1.5 inches across. Either that gear breaks or the cog inside of it shears off and this causes the fuser not to turn. Very inexpensive part at less than $15 and pretty easy to change.
As far as the fingerprints go you most likely touched the drum surface. You may have to remove it again and clean your fingerprints off the drum with a soft cloth.
Oct 20, 2009 | Xerox Office Equipment & Supplies
Ghosting on my laser printer
You just need to run more print outs to clear the ghosting.
Apr 10, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Hp officejet k8600 printer won't print
after going thru this machine, i found cleaning station not working, well, motor is same as those on office jet 7110 series, so if that is problem switch out motors, and test
Mar 01, 2009 | HP OfficeJet Pro K8600 Printer
Making a loud noise when the paper is feeding.
This is what the HP website says about noises in the 1610..
Issue Unexpected noise (clicking, thumping, grinding, squealing, and so forth) from an HP all-in-one can be caused by a problem with the ink carriage or the scanner. Solution Follow the steps below in the order presented to determine the source and resolution for the noise. Step one: Checking the scanner This step applies only to products equipped with a flatbed scanner.
  1. Open the scanner cover.
  2. With the lid open, press the Start Copy button to make a copy. The scanner mechanism should move down the glass.
  3. If the scanner mechanism does not move and noise is present, contact HP. If the scanner mechanism moves without noise, continue with Step two below.
Step two: Checking for paper feed problems and carriage blocks Click here (buu03110) (in English) for more information on paper or carriage jams. Step three: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. So it sounds like it needs to be serviced which could get expensive. I've looked all over the web for you & Keep finding the same answer. Sorry I can't come up with a better solution for you.
Nov 29, 2008 | HP PSC 1610 All-In-One InkJet Printer
Doesn't print!
u sure litte thing on new ink is off platci cover that protects them download the latest driver ok from kodak website try it again thx nick
Jun 16, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Wants to print but won't put ink on paper
I'm experiencing the same problem. I tried to troubleshoot through software that came with printer, but no luck. Here's what happens:
The printer worked great for a month or so. Then, I didn't use it for a few months. When I tried to use it again, it acts like it's printing. My computer shows it's printing, the printer runs through all the steps, including moving the print cartridges back and forth over the paper as it should, but no ink comes out on paper.
Any suggestions?
Nov 05, 2007 | Lexmark X1270 All-In-One InkJet Printer
old marine
old marine
