Question about Sharp AR-M237 Copier
RESET H2-01 SHARP AR-M237 - Sharp AR-M237 Copier
Cogz
  • 1326 Answers
SOURCE: Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
Posted on May 09, 2008
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
sir fixalot
  • 146 Answers
SOURCE: Sharp AR-M237 Error Code H4-21
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
If the error code recurrs ther are other problems.
Posted on Jun 06, 2008
Bubbabear64
  • 2794 Answers
SOURCE: IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Posted on Oct 16, 2008
  • 257 Answers
SOURCE: sharp AR-M237 DISPLAY READS CALL FOR SERVICE CODE H4-20
Use # interrupt c interrupt . Then enter 14 press Print key. If it re-appears, call a specialized technician.
Posted on Jun 26, 2009
Sharp AR-M237 driver
You can download any driver you need from the link below.
Also, there are instructions for installation linked on the page.
Sharp Print Driver Download 64bit and 32bit Free Printer Driver Download
Jun 29, 2014 | Sharp AR-M237 Digital Copier
F2-02with sharp ar-275
Toner supply abnormality
check toner motor and DV mag sensor
Jun 14, 2014 | Sharp AR-M237 Copier
En la fotocopia dora me aparece llame al servicio tecnico COD.U2-40 y no me saca copias copiadora es SHARP AR-M237 AYUDENME
Hola buenas tardes, me podrian ayudar tengo una copiadora sharp ar m237 y me esta marcando el codigo U2-40 y no se que hacer alguien pude hacesorarme
Jul 20, 2011 | Sharp AR-M237 Copier
How to problem sharp AR-M237 erroe code H4-01
you have problem with the fuser temprature maybe the the heater lam or may be thermal fuse just check bothe if ok just reset.
thanks
May 22, 2010 | Sharp AR-M237 Digital Copier
How do you reset the admin password for web login access on the Sharp AR-M237?
You must delete the printer and all software and reinstall. maybe a Tehnician can be PERSUADED to give you the default passwords.
Oct 23, 2009 | Sharp AR-M237 Copier
Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Oct 08, 2009 | Sharp AR-M237 Digital Copier
I need to change the IP for my ar-m237
Try to increase the router range to include the ar-m237 or change the copier to a lower IP address within the range of the router.
Jan 03, 2009 | Sharp AR-M237 Copier
May 08, 2008 | Sharp AR-M237 Digital Copier
Reset Code
Did you do a PM on the copier? Or do you just want it off the display? You need to get in to service mode with pressing "#" "Interrupt" "Clear" "Interrupt" then enter 24 "Start" then go to sub code 04 then press OK to clear count. To exit press "CA" Good Luck
Sharp AR-M237 Copier Logo
69 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
