Question about Woods Industries 59377 Indoor Digital Timer 7-day
How to change wood timer to 12h from 24h - Woods Industries 59377 Indoor Digital Timer 7-day
  • Woods Master
  • 5,245 Answers
Http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Not all timers offer choice between 12 am-pm and 24 hour formats.
Download manual
Usually the 12-24 option is first step in programming after pushing reset button
Gene
Posted on Oct 19, 2014
Setting military time
If you mean switch from 12h to 24h and vv,all you have to do is to press the "ADJUST" button until digits on the display blink.Then press the "MODE" button until 12H blinking appears.Press the "START-STOP" button to switch to 24H.When finished press the "ADJUST" button again.
Dec 14, 2013 | Casio G-Shock G-Rescue Tide Graph Watch
This is a Disney watch. Somehow I messed with it and changed it to military time. Does anyone know how to change it back.
One of ur buttons is a "set" button..press it a couple of times or press and hold it for a few seconds..the screen will read "12h or 24h..make sure it clicks on 12 or 12h and that will change ur time display back to normal...
Dec 05, 2012 | Televison & Video
Intermatic digital lamp timer dt300. I can only get to set it to 24 hour. it does not go to 12 hour when i reset and then hold down the clock button. what am i doing wrong?
There is no repair for defective timer.
The DT300 is sold under at least 3 different brands and product numbers, and each manual shows identical steps for choosing 12H and 24H format.
The manual says to press and hold CLOCK button until display shows 24H. Then press HOUR button to change to 12 hour format.
I am guessing this step cannot be done if timer has programming in memory, so timer has to be reset first by pushing in reset button for a few moments.
Open following links to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Intermatic Hardware & Accessories
Problem #1. On model #DT300 the instructions under Set Time of Day # 3 does not change the day. The only place I can get the day/s to change is under the programming. What is wrong with it. I have...
Thank you for very clear question, and timer identification.
1) I don't have repair for defective timer.
2) Choose DT300 format
#3 says to press-and-hold CLOCK button until display shows 24H or 12H
Then release CLOCK button.
Next press HOUR button to select either 12H or 24H
This lets you choose am-pm format -or- choose military-time format where 11pm is 23
3) Set current time
Press-and-hold CLOCK button throughout whole current time setting.
Do not release CLOCK button until current time settings are finished.
Next, press HOUR button, and then MINUTE button, and then DAYS button until current hour, minute and day display.
If this step does not work, then timer has gone bad.
Replace with locally available Utilitec 155671 from Lowes or Westek TE06WHB from Target
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
4) How to set DT300 timer program for full week of operation.
Each program requires you to set program 1 ON time and program 1 OFF time
Be careful to avoid program conflicts and overlaps so timer works as expected.
For program 1 ON time, you press PROGRAM button until 1 and ON display.
Release Program button.
Then select hour, minute and days. In this case you want all days of week, so you keep pressing DAYs button until whole week displays: Mo Tu We Th Fr Sa Su
Then you set program 1 OFF time, you press PROGRAM button again until 1 and OFF display.
If you set ON time for all days of week, and OFF time for Tu Tuesday, then timer will not work correctly.
5) Read manual and add a comment for additional help
Aug 18, 2011 | Hardware & Accessories
On my Casio G-shock GW500A, the time is off. i dont want it on 24time and its an hour ahead
Sounds like you're set for the wrong time zone, and your 12h/24h setting is off.
To change time zone: Hold down the adjust button until it beeps. Your time zone will be flashing at the bottom of the display. Use the Time Memo and/or Receive buttons to change it to the correct time zone. Then... To change to 12H mode: Press adjust again. 12H or 24H will be flashing at the bottom. Use the receive button to cycle the mode. When it's what you want, press adjust once more.
Feb 26, 2011 | Casio G-Shock GW500A-1V Wrist Watch
On my Tissot t-touch expert, i need to know how to change
1. touch middle of screen till you see 24h Cm or 12h Cm
2. press middle button
3. top button changes Cm to Fft (celcius meters to farenheit feet)
4. bottom button changes from 12h clock to 24h clock
Apr 05, 2009 | Tissot T-Touch T33759851
How to get from military time to standared time no instructions manuel
Hold "Set"
use "mode" to browse
when you get to time setting the 24h/12h setting should be first thing you can do. press "St/Sp" button when you see the "24h" icon flash it should switch to "12h"
Press "Set" You are done!
Jan 06, 2009 | Columbia All Sport Digital watch
Changing to metric
1. Activate Crystal
2. Tap center until units screen appears (This will say either 12 or 24h and F ft or C
m)
3. Press and hold top + button until watch beeps, display will be flashing.
4. While flashing, press top + button which will change the C m to F ft and back
5. While flashing, press bottom – button which will change the 24h to 12h and back.
This will also change the date format. If in 24h the date will be Date/Month, if in
12h it will be Month/Date.
Oct 03, 2008 | Tissot T-Touch T33759851
How do i set the time on 1440 T5K085
The instructions that came with my watch didn't work but after playing around with the buttons for a while i final came up with this: Press the mode button for 2 secs. The first display is the alarm. Press mode again and the time shows with the seconds flashing. Use the set button to change seconds, minutes, hours. Use the start/stop button to change from seconds to minutes to hours.This will then take you to change the month, date and day of the week. Mode takes you back to the start (time display). The alarm is changed in the same way.
To change from 12h clock to 24h clock keep the set button pressed (the alarm time is displayed) and press mode, the 'A' will disappear when in 24h mode
When the time is displayed press the start/stop button to show the date.
Not sure how to use the countdown timer or how to stop the alarm yet though!
Aug 13, 2008 | Timex Watches
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
Woods Industries 59377 Indoor Digital Timer 7-day Logo
79 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
