Question about Amana Heating & Cooling
We have Amana Model RCC60A2B, Serial #102139491. Where is the reset button located?
A friend's Amana dryer (front load) does not start. It beeps when she pushes the start button.
The model/serial number should be on the back of the appliance.
This will tell the Company if it is still under Warranty. Call 1-800-555-1212 for Amanas number, if you don't already have it. Good Companies will stand behind their product, and help you!
Aug 27, 2014 | Amana Dryers
How do i remove and replace heating element and where is it located
Here is the element to order.
Here is a video to show you how to replace the element. The model may be a little different but the process is the same.
Feb 14, 2013 | Amana Dryers
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Looking for wiring diagram for amana bottom freezer model # BG20T2L MFG# p1316303wL serial # 9807110676 THE ICE MAKER QUIT MAKING ICE
First thing to check is the fill tube and make sure it is not frozen with ice.some ice makers can be manually advanced in order to refill with water some have a reset button to do this if these two things do no good and the fill tube is not blocked with ice then repalce the water fill valve on the bottom rear of the unit
Jul 10, 2010 | Amana SXD524VW Side by Side Refrigerator
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
Dryer won't run. Stops after 30secs
Sounds like the timer is going bad and it needs to be replaced. The time is located behind the knobs.
IF my answer has satisfied you please rate. Thank you
Feb 11, 2009 | Amana ALG331RAW Gas Dryer
Amana side-by-side icemaker buttons on door not working properly
I have an idea whats wrong but it amy be kinda hard to explain to you but here goes.
looking at the selector buttons does it look like the plastic overlay is cracked or worn from where you have made selections over time? what happens is when these selectors crack it causes teh switch to hange in one position. in your case it would most likely be the water button that is the worst culprit. the repair is very simple. you need to replace the overlay which is the sticker that labels the crushed/cubed ice and water. you can order this part through amana using your model and serial number, or post a good model and serial number here and I'll look up the part for you. thx peyton
Jan 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Heating & Cooling Logo
60 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
