Question about Home
Bucherer clock instruction manual
Instruction manual for setting chimes
5 Suggested Answers
SOURCE: Seiko Westminster Chime Clock; Model No. QQF150G Caliber 12105
Does this help
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
  • 61 Answers
SOURCE: How do you syncronize the chimes to the actual
Are the hands held on by a nut? usually you can remove the nut with your fingers or a pair of pliers wrapped in cloth or duct tape to prevent scratching.
Before removing turn the minute hand (minute hand only and clockwise only; do not manually turn the hour hand and never counter-clockwise) turn the minute hand clockwise until it chimes at an hour mark.
Then remove the hands and and place them pointing to the correct time.
If you are uncomfortable with this I recommend taking it to a clock shop or jeweler that sells clocks. If it is inherited, it may need some maintainence (oiling and regulating) anyway.
Posted on Oct 17, 2009
  • 15 Answers
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Posted on May 10, 2010
  • 5 Answers
SOURCE: Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
Posted on Jun 05, 2010
It wont chime on the hour
Basic assumption... The chimes know what time it is...!!
FORCE NOTHING...!!
From page 10 of owners manual below (MINUTES):
EXAMPLE: Clock chimes at 1:10 but should chime at 1:15.
Step 1: When clock chimes at 1:10 stop the pendulum and record the time of 1:10.
Step 2: Carefully remove the small nut....
(Hour procedure is on the SAME PAGE (10).
WARRANTY INSTRUCTION MANUALS
Apr 19, 2016 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
Need instructions on how to set chimes
what kind of clock do you mean please, can you please add more detail and resubmit the query. If it is normal clocks you are referring to to. Computer closks, device closks, cooker clocks
Jun 04, 2015 | Home
My Gazo GF Clock won't chime on hour at all
When you are setting your clock, when you go pass the hour you have to let the clock chime completely, if you do not do this you can damage the time sequence..You have to reset the chime cable or belt...but anytime you set your clock when you get to hour let it chime completely before continuing on...Try also going around with hour hand onetime and let it chime, if it will chime at all, if not you can get a manual download online. Clocks like yours has websites and support who can help you...I think it just needs the chimes reset.
Dec 17, 2014 | Home
Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Apr 21, 2010 | Watches
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Fred
Apr 05, 2010 | Seiko Mantel Clock
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Need setting instructions for clock movement
Howard Miller offers this feature: This is how it works.
Automatic Night-Time Silencing Option
Grandfather Clocks will offer a night time shutoff option. There are 3 options on this lever.
1) "Night On" - This will keep the chime striking 24 hours
2) "Night Off" - This position will turn off the chiming between 10:15PM and 7:00AM
3) "Strike" - This position will allow the movement to strike the hour without the Westminster melody if the other Westminster melody lever is turned to Silent.
Hope this helps.
R/David
Apr 05, 2009 | Oregon Scientific Lwb0997110113004...
Instructions for Sunbeam clock model # 882-495
Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/auto.off is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
Mar 29, 2008 | Office Equipment & Supplies
Home Logo
54 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
