Question about Sony VAIO Computers & Internet
Computer is going into a slideshow of all the open screens, and it can only be stopped momentarily before it starts cycling through the screens again. The only way to stop it is a restart.
SOURCE: SPIN CYCLE
Front load Neptune model
Posted on Nov 25, 2007
hotuna
  • 288 Answers
SOURCE: Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Posted on Dec 23, 2007
  • 1073 Answers
SOURCE: DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
Posted on May 11, 2008
aborcass
  • 2651 Answers
SOURCE: My duet washing machine throughs out a FH code
FH is a water inlet related issue, make sure your cold water supply is working correctly, sounds as if its trying to rinse(cold water) and has no water to do it
Posted on Dec 22, 2008
SOURCE: Dell E173FP Monitor Problem
My Dell E173FPc exhibited this same problem as described by many people on this site. Having looked through the solutions I decided to investigate further.
Posted solutions point to a faulty 12V smoothing capacitor, dry joints on the inverter transformer or faulty driver transistors. All these were Ok in my case, but on closer inspection a dry joint was found on L202 – see picture.
Cleaning off the old solder and re-soldering fixed the problem.
So if your monitor exhibits the same symptoms carefully inspect all the solder joints of large components around the inverter.
Posted on Feb 10, 2009
Kenmore side by side 253.52349302 making stalling noise
motors start capacitor relay may be going bad..
Jan 20, 2014 | Kenmore Refrigerators
Tip
How to make a Media center Shortcut.
Windows 7 Media center have multiple switches for customization.
Here is a list bellow.
/nostartupanimation stops the startup sound and Windows Media Center logo "pebble" going off into the distance /noshutdownui removes the "shutdown" item from the tasks menu /mediamode starts in media only mode (no close/minimize/maximize options in top right corner) /widescreen start in widescreen mode, even on 4:3 display (windowed only) /nochrome display windowed mode Media Center but without the window chrome /playallmusic plays all your music instantly /playfavslideshow plays your favorite slideshows only /playfavslideshowwithmusic plays your favorite slideshow with music /playslideshow plays all slideshows /playslideshowwithmusic plays all slideshows with music /screensaver starts the Media Center screensaver /configuress starts Media Center at the "configure screensaver" screen Examples: %windir%\ehome\ehshell.exe "/mcesuperbar://tv?live=true" – That will start Media Center in LiveTV mode
Yo can create custom shortcut by doing the following : Start > All Programs > Windows Media Center, and right click on it. Select properties. Under "target" you will see "%windir%\ehome\ehshell.exe".
Simply add the switches you wish Media Center to start with and hit OK.
For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
on Feb 10, 2010 | Computers & Internet
Tip
Polaroid IDF-1030 Digital Picture Frame - Slideshow with Music
The manual for the Polaroid IDF-1030 is ridiculously simple and not very helpful. There's actually more information on the outside of the box.
One of the features that is not intuitively easy to figure out is how to get the frame to display a picture slideshow AND play music at the same time. The remote is the only way that you can set this up.
First, on your computer, create a folder for the images and a folder for the music. If you put music in the images folder, your slideshow will stop at the first music file it finds and just display the music player's equalizer interface. This is very boring.
Note on the pictures.. spend a little time and reduce the size of your pictures to 640 x 480 pixels. Dealing with large files on the photo frame is painfully slow.
images should be in JPEG (.jpg) format although it will also display .gif files. Music should be MPEG (.mp3) format.
Copy these folders to the root of your memory card.
Put the memory card in the Polaroid frame card slot and turn it on.
Use the remote and press the STOp button if it automatically starts displaying the pictures.
Press the MUSIC button and select the REPEAT button until you see REPEAT ALL at the bottom of the screen.
Press the PLAY/PAUSE to start the music, then immediately press the SLIDESHOW button to start the slideshow with music.
I hope this helps some of you who had trouble with this.
on Jan 07, 2009 | Polaroid IDF-1030 (826219006783) Digital...
In ma laapi i m not able to make a slide show help me
Put all the pictures you want in the slideshow into one folder.
To create a new folder just RIGHT MOUSE CLICK on an empty spot on your desktop, scroll down to the word NEW, then over to the word FOLDER and click on that.
The new folder will appear on your desktop and then you just name it whatever you want.
You can either drag your photos into that folder with the mouse or COPY and PASTE them there.
Now double click on the folder to open it up.
On the left hand side of the page under expand the PICTURE TASKS menu.
In there you will see an option to VIEW AS SLIDESHOW.
Click on that and your slideshow screen will appear and the slideshow will start playing.
The PLAY (start slideshow) button will be in the upper right hand corner.
The PAUSE, NEXT PICTURE, PREVIOUS PICTURE and the CLOSE SLIDESHOW SCREEN buttons will be up there too.
Good luck and please comment back and rate if this was helpful or if you need further assistance.
Feb 12, 2011 | Computers & Internet
WATER IN WASHER WONT SHUT OFF
Hi and welcone to FixYa. I am Kelly. When water wont shut off no matter what you do the problem is inside of the water valve assy. Usually there is a small bit of debris in the diaphram center hole that is holding the water passage open.
Here is what you can try to do to clear if BEFORE replacing the eater Valve.
1. Get a bucket
2. Turn off both water supply hoses momentarily
3. Set the water temp to warm
4. Remove ONE hose from the wall connection and place the hose in a the bucket.
5. Turn on the remaning connected hose/
6. Start machine fill cycle and tap the hose connection at the water valve on the back of the machine with either a screw driver or hammer handle.
Timer OFF
REVERSE HOSE CONNECTIONS ON THE WALL CONNECTION.
7. Place the other hose in the bucket
8. Start Fill cycle.
9. Again tap the hose connection at the water valve
10. Stop timer.
11. Reconnect both hoses and test for water flow with timer off.
12. Start fill cycle
13. Rapidly select hot and cold wash water.
14. STOP fill cycle.
15. Remove each hose individually from the water valve one at a time.
16. Use a knive blade and remove the inlet screen from the water valve. Wash screen under slowly running water rubbing it clean with your fingers. Re install screen. Reconnect water hose.
17. Repeat step 16 for opposite hose and screen.
18. Turn on water supply.
19. Test for proper filling and water stopping by starting and stopping fill cycle.
If it works you got lucky. If you still have the problem you will need to change the water valve. Either one of these water valves will work on your machine:
http://www.repairclinic.com/Appliance-Parts?s=t-PAV2300-%3d%3dc292d509361
Thanks for using FixYa.
Kelly
That is about it
Jun 05, 2010 | Maytag PAV2300 Top Load Washer
Apple laptop will not start
Get your Mac OS disk out and restart your computer with the disk in the drive ANd while holding down the C key. This will start the computer on the OS disk system.
Once you get to the desktop, look for the top menu and launch Disk Utility. Run a repair and see if you get any indications that it found anything out of the ordinary.
Then restart as normal.
If it still doesn't work, I would recommend reinstalling the system software.
Jun 02, 2010 | Apple MacBook Pro Notebook
After pushing on button, cycle begins and light comes on momentarily and then stops. Cycle does not proceed. Light goes off.
Possibly the door switch is opening. Try holding in the door and starting. If it continues as long as you hold the door, adjust the door interlock switch.
Nov 14, 2009 | Dishwashers
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Jan 10, 2009 | E-Machines T2742 PC Desktop
SPIN CYCLE
need more information is it top load or front
Nov 19, 2007 | Maytag Neptune MAH5500B Front Load Washer
Toshiba PDR M700 Slideshow
Have you tried pressing the 'down' button?
Good luck.
Aug 12, 2007 | Toshiba PDR-M700 Digital Camera
Computers & Internet Logo
20 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
