Change its setting from atomatic to mamula and then via using you computer go to RUN type CMD and then there type Ping you will get IP address from here then paste it on Ps3 internet setting..
1. On the XMB go to Network Settings
2. Next go to Internet Connection Settings
3. Choose Wireless
4. Choose Enter Manually in WLAN Settings
5. Enter your SSID (your wireless network name)
If you have internet security, enter it after this.
6. Under Address Settings, choose Custom
7. Under IP Address Settings, choose Manual
8. Input your information (exactly as shown):
IP Address: 192.168.0.105 (enter your own IP)
Subnet Mask: 255.255.255.0
Default Router: 192.168.0.1 (if you know your router already, use that number)
Primary DNS: 4.2.2.2 (it is important that you use these numbers)
Secondary DNS: 4.2.2.3
9. Continue on to MTU and choose Automatic
10. Continue on to Proxy Server and choose Do Not Use
11. Continue on to UPnP and choose Enabled
12. Click X to save your settings
13. Test your connection and see if this helped or not.
If problem still remains, let me know.
Hope i helped you.
Thanks for using 'Fixya'.
SOURCE: PS3 will not obtain IP address
Perhaps resetting the router will solve your problem. Have you tried that?
SOURCE: trouble obtaining ip address
When you put the IP address in you also have to add your DNS settings. easiest way to find your DNS server address is to use an XP based machine and type "ipconfig /all" it will list all of the properties of your computers network card. thake those DNS address' and plug them into your PS3.
still failed says the attempt to obatian ip adress timed out
