Question about Exercise & Fitness
What does Code E5 mean on a Vision Fitness Treadmill T9500
maxtreadmill
  • 832 Answers
SOURCE: squeals on startup for about 1 minute then goes
Remove motor shroud and inspect the drive belt VF is imfamous for squealing drive belts better to call them and order a new belt here is their # 1-800-335 4348 Vision is now under there parent corp. name Johnson
Posted on Feb 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Posted on Mar 01, 2010
guru_fixya
  • 944 Answers
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
AJIN G
  • 6694 Answers
SOURCE: I have a vision T9500
hi,
Try AUTO-CALIBRATION first. For that do the following.
With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START.
(The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen)
If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module.
OK
Posted on Aug 28, 2011
SOURCE: e5 error code on sportcraft tx400 treadmill
E5 erorr code for my gait keeper treadmill ,it starts up after few seconds ,it stops
and error code appear.Can you tell me what this means? How to solve this problems?
Posted on Mar 15, 2012
How many amps in the Vision Fitness T9500 HRT Treadmill
it is a 3 horsepower motor, but no amperage specified. The review does say this model has drawbacks.
Vision T9600 HRT Comfort Treadmill review
However, I found this, so 23 to 28 amps based on a 3HP motor.
Note: the following table contains approximate full-load currents for motors of various types, speeds, and frequencies. Variations of ±10% may be expected.
Hp. of
Motor
Current - Full-Load (Amperes)
Direct-current Motors
Single-phase Motors
115
volt
230
volt
550
volt
110
volt
220
volt
¼
4.8
2.4
½
4.5
2.3
7
3.5
¾
6.5
3.3
1.4
9.4
4.7
4.2
1.7
11
5.5
1 ½
12.5
6.3
2.6
15.2
7.6
8.3
3.4
20
10
12.3
5.0
28
14
Oct 06, 2015 | Vision Fitness Exercise & Fitness
Does anybody know how to get the total milage on the vision t9500 deluxe treadmill? it is a 2007 model.
please go to www.iconservice.com and download your owner manual for instruction about the how many total milage.
God bless you
Aug 23, 2013 | Vision Fitness Vision T9500 Deluxe...
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
Belt is slipping
see the video attached. and fix it. God bless you
Nov 25, 2012 | Dmm Vision Fitness T9500 Treadmill
Vision fitness manual for t9200
see this place and download the instr.manual www.iconservice.com or www. fitness.manualsonline.com
God bless you
Jun 27, 2012 | Dmm Vision Fitness T9500 Treadmill
I have a vision T9500 treadmill. My husband was recalibrating and it got stuck in the highest position and is displaying E5 in the window. Any ideas how to get it down?
hi,
OK
Aug 27, 2011 | Dmm Vision Fitness T9500 Treadmill
I have the Vision Fitness treadmilll #T9450. When
Take the front cover off and see if the drive belt is on the motor. Try running it to see if the motor turns. This could be a motor or controller board problem.
Jun 15, 2010 | Dmm Vision Fitness T9500 Treadmill
Just bought a 9250 vision fitness treadmill and when we first plugged it in the screen stays blank?? What should we do?
First Your outlet to see if power is their, then check on/off switch usually their is an internal light in the switch to show power is to the switch then check the breaker button next power switch. these are a few things to look at. Check if the safety key in place on the upper console
Feb 01, 2010 | Dmm Vision Fitness T9500 Treadmill
Squeals on startup for about 1 minute then goes
Exercise & Fitness Logo
43 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
