Question about Toto Carlyle 1-piece Elongated Bowl Toilet
New saniflow takes 6 flushes to get rid of solids, is it broken?
Toilet has 2 levels of flush half and full flush. Even with a full flush it takes many goes for solids to leave the toilet bowl.
  • 10865 Answers
SOURCE: toilet flushng
It sounds like you have an obstruction in the toilet or in the drain line it feeds into. I would begin with a strong toilet drain cleaner. Be sure to read the directions and select the proper cleaner. If that doesn't work the next step is to pull the toilet off of the floor and phyically check the toilet and the drain beneath it. Before you start this project be sure to turn off the water to the toilet and flush so you don't have too much water to deal with. Also be sure to have a new wax seal on hand to reset the toilet. good luck.
Posted on Jan 21, 2009
  • 659 Answers
SOURCE: Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Posted on Mar 21, 2009
  • 3600 Answers
SOURCE: Increase water in toilet tank-low flush Toto toilet
Yes adjust the float level to raise the amount of water in the tank, If you have a float that is a ball around the tank you will have to turn the water off and remove the hose from the tank and remove the nut then pull the water float device out and you will see a clap on the bottom of the float you will turn the float base so that it gets longer, increase it by two inchess so that you increase water flow. Reinstall into the tank hook it all back up and leave the lid off turn on the water and watch the water level rise be sure the float shuts the water off before it over flows, if it starts to over flow then fush it to bring the water down giving you enought time to shut off the water valve.
There is a problem adding low water systems to older septic systems. The septic pipe settles in the ground over time and may cause a ~~~ in the pipe thus causeing blockage. For future reference you can add a one gallon bottle of water in the tank like a milk jug or a used up bottle of puerified water that you have drank and this will decrease it by one gallon per flush. Hope this helps. If you need more asstance just posttothis reply!
Posted on Nov 11, 2009
  • 17 Answers
SOURCE: toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Posted on Jan 23, 2010
mkh5094
  • 145 Answers
SOURCE: Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
Posted on May 18, 2010
Half flush does a full flush
It's not nessesarily a half flush just as little water as is possible for that toilet. The full flush has just a little more. It may be hard to tell the difference.
Nov 23, 2013 | Home
Pump randomly runs
This problem maybe caused by a slight weep of water from the cistern the saniflow has a sensitive float system , once level is reached the unit will turn on until required level is acheaved again . So check toilet bowl to see if the is a trickle of water if so you need to take a look at the flush system in your cistern.
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
Nov 17, 2012 | Saniflo & Saniplus& Macerator Pump
Toilet wont flush
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
I have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
find water pressure regulator. it will have a bolt coming out of the top with a nut at the base of it.loosen nut. while toilet is being flushed, adjust bolt till noise stops. turn bolt clockwise to adjust.
Dec 17, 2011 | Taylor Home
Saniflow system keeps frequently flushing even when the system isn't being used. the system is working normally but it keeps flushing through the day and night.
Need to check the flapper inside the toilet tank. this is what opens when you press on the toilet handle. you may need to replace it or replace the whole flush valve assembly.
Nov 07, 2010 | Saniflo Home
I have a Carlyle water saver toilet. The one that has two push buttons built into the toilet tank lid. It is a solid 1 piece toilet. My problem is every hour the toilet is flushing by itself. Had a...
Hello. Your lid has two buttons so you can do a half flush or a full flush. A water saving feature. Since the toilet is flushing by itself every hour or so, you must have a leaking flush valve. Replace the valve to solve that problem. Joe
Oct 12, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Weak dual flush does not empty the toilet bowl.
well, yes... but apart from providing you with a forum in which to vent your frustration I'm not sure how you think we might help. I have the same problem with a dual flush cistern, but in my case I know that the root of the problem lies in the fact that the soil pipe leading from the bowl has insufficient fall (because the previous owner of my house moved the toilet further from the down pipe). Maybe something like this is contributing to your problem too?
Jan 21, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
Water leaking out of breather
I have a question, I have a saniplus no problems hooking it up filled the tank and then flushed it..On the discharge end I had a small about of water puddling up at the pressed in rubber fitting. Every clamp was tight not sure what the reason is any ideas. I thought about silcone around the rubbber seal between the lid.
Sep 08, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Master bath toilet replaced with a Cimmeron class 6 confort height toilet. The master bath toilet backs up to the hall bath toilet - same wall. The hall toilet is very old. When the old toilet is flushed,...
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Mar 16, 2009 | Kohler K-3489 Cimarron Comfort Height...
Toto Carlyle 1-piece Elongated Bowl Toilet Logo
41 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
