Question about Samsung Ak59-00104l Remote Control
How do I program a ak59-00166a to turn on a toshiba led tv
I lost the instructions for operating my 3300 one for all remote control. Please help me program my Toshiba tv so I'll be able to operate my tv set.
Turn on your Toshiba TV. On your remote, press the TV key. Press and hold the SET key depressed until the red LED blinks twice, then release it. Press the 0, 1, 5, and 4 keys. Point your remote at the TV and press the POWER key. Your TV should turn off. If not, repeat the programming routine pressing the 0156, 0060, or 1256 keys
Oct 03, 2013 | One For All URC-3300 Remote Control
Vextra remote codes for toshiba tv
How to auto program this remote
1. Turn on the device to be programmed.
2. Press and hold SET for three seconds
3 Press the corresponding Device Button (TV, SAT, VCR, DVD,CBL,Audio)
4. Aim the remote at the device. Press the power button once and release. Each time the Remote searches for a code, the device button LED flashes twice. When the device turns off, immediately press ENTER to save the code (before the device button LED flashes again) This could take several minutes.
Aug 21, 2013 | Computers & Internet
I need remote codes for a src-300a to a toshiba tv
One of these three codes should work: 0156, 0060, 0154
In addition, here are the commands to get your remote into programming mode should you require them.
  • Press the LED button and hold it down until the LED Flashes.
  • Press the REC button. The LED stops blinking at this point and stays solid.
  • Press and release the POWER. The remote is now in TV Code Scan Programming Mode.
  • Press the UP ARROW (above SELECT) button to scan through all the TV codes. When you reach the correct TV code, the TV will automatically turn off.
  • Press the SELECT button to store the TV code. The LED flashes rapidly then stops, indicating code has been stored.
Dec 26, 2011 | Motorola Televison & Video
How can I program my remote to a Toshiba 60"?
Here are the codes for you Toshiba TV: 631, 617, 635, 744, 615, 667, 590, or 688.
I have provide instructions on how to program your remote to your TV.
  • Remotes: Basic (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press #. Note: The LED will flash three times.
    5. Test functionality with the TV.
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 18, 2011 | DISH Network 135899 Remote Control
I need a code to make my time warner remote control to work for my toshiba tv
According to timewarnercable.com, the codes for a toshiba tv are 074, 168, or 170. If none of these codes work, I suggest you try the code search function. To do this, follow the steps listed below. 1. Turn on the tv 2. Press "select" and "tv" together until the LED blinks twice. 3. Using the keypad on the remote, type in the digits 9-9-1. This will open the "code library." The LED should blink twice. 4. Press "power." 5. Press "channel up" key repeatedly until the tv switches off. 6. When the tv turns off, press "tv" on the remote to lock in the code. Your remote should now be programed to your tv. I hope this helps, and good luck! Sincerely, Der Strom
Apr 27, 2010 | Toshiba 36A50 36" TV
I need the toshiba 4 digit code to program my Oneforall remote.
To control a Toshiba TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0154, 0156, 0060, 1356, 1656, 1704, 0650
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Nov 10, 2009 | One For All URC-3021 Remote Control
Need rca univeral remote code for a toshiba tv
1. Manually turn on the component you want the remote
to control.
2. Press and hold the component key (TV, DVD•VCR, AUX, SAT•CBL) you wish to program. The LED INDICATOR turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the LED INDICATOR blinks four times, and the process is exited.
3. While holding down the component key, enter the four-digit code. While you are pressing the numbers, the LED INDICATOR turns off.
4. After the fourth number is entered, the LED INDICATOR turns on. At this time, release the component key. If the LED INDICATOR turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry.
If the LED INDICATOR blinks four times when the component key is released, This means that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2.
RCA Toshiba 3 digit codes. 000,018,021,023,048,049,071,072,073,085,...
RCA Toshiba 4 digit codes.1000,1048,1072,1105, 1109, 1118,1160,1190,1241 Good Luck
Jun 14, 2009 | Televison & Video
I'm missing the instruction manual for my RCA RCR460 remote control. I need the manual set-up instructions, and a list of all the potential codes to sync up to a Toshiba or Mitsubishi DVD player. Any help...
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box). Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR, DVD, SAT·CBL, ON·OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained. 2. Press and hold the component key (TV, VCR, DVD, SAT·CBL) you wish to program. The LED indicator light turns on and remains on. 3. While holding the component key down, press and hold the ON·OFF key. The LED indicator light turns off. 4. After holding down both keys for three seconds, the LED indicator light turns back on. 5. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control. 6. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Press Stop when TV turns off.
Jul 06, 2008 | RCA RCR460 Remote Control
Big Easy programming
TV Toshiba 0154 0156 0060 1256PROGRAMMING
TV/VCR COMBO CONTROL
Perform the following instructions to
control a TV/VCR Combo:
1. Turn on the TV/VCR Combo and
insert a video cassette.
NOTE: Please read steps 2-4 completely
before proceeding.Highlight or write down
the codes and device you wish to program
before moving on to step 2.
2. On the remote control,press VCR/DVD.
3. Use the Setup Codes For TV/VCR
Combos (on the back side) to locate
the brand name and then enter the
first four-digit code for your device.
If performed correctly, the LED will
blink twice.
NOTE: If the LED did not blink twice, then
repeat steps 2 through 3 and try entering
4. Aim the remote control at the device
and press POWER once. It should turn
off. If the device does not respond,
repeat steps 2-3, trying each code for
your brand until you find one that
works. If it still does not work, try
Searching For Your Code.
NOTE: If the device does not have a
POWER key, press the (PLAY) key.
hope that helps
Jun 26, 2008 | One For All URC-3300 Remote Control
Samsung Ak59-00104l Remote Control Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
